Car Repair Forum - Ask a Question, Get a FREE Answer.
Go Back
2002 Audi A6 Humming noise when turning at low speeds
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Wed Jan 09, 2008 5:14 am |
By
sekhri10,
New to the forum |
Give Feedback | Votes: 0 |
Other Category problem
2002 Audi A6 6 cyl All Wheel Drive Automatic 67000 miles
My car is making a humming noise when I turn at low speeds (backing out of driveway, navigating through parking lots, etc.). I took it in twice and the first time they found the front brake rotors were warped so they replaced those and the noise went away for a few weeks but then started coming back again. I took it in a second time and they found corrosion around that area which they said can happen due to weather. So they hit the brakes hard a few times and the corrosion came off and the noise went away. I just got my car back the other day and I can still hear a slight noise again. Is there something else that may have been overlooked? I know that the car shouldn't be making any noises. Any help would be appreciated. Thanks.
| Find a
car repair manual for your Audi A6 Repair Question. |
By
Advertisment,
| Find a
Posted at Thu Jan 10, 2008 4:49 am |
By
sekhri10,
New to the forum |
Thanks for the quick response. I hear the noise when I'm turning at idle speeds. It usually occurs when I'm backing out of my driveway or navigating in my work's parking lot. The noise doesn't occur when I'm pushing on the brake. It occurs when I turn and my feet aren't pushing on the brake or the gas. Any ideas on what that may be?
| Find a
Posted at Thu Jan 10, 2008 6:49 am |
By
mhpautos,
Certified 2CarPros Master Technician |
                      (462) Give Feedback | Votes: 11 |
Hi there,
I would jack up each wheel and spin the tyre by hand, have a close listen, if you can hear the noise, remove the wheel and turn rotor, check for something touching the rotor, something stuck between the rotor and the backing plate, or the backing plate touching the rotor, start to narrow it down that way. see how you get on.
Mark (mhpautos)
| Find a
Posted at Fri Mar 28, 2008 10:20 pm |
By
wii2,
New to the forum |
I have an audi a4 and I had that problem as well. When I took it to the shop, they told me it was the power steering pump that was making that noise. It had been leaking or something so thye replaced it. The noise was gone by after about 5-6 months it's back now but only occasionally which is odd.
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
