Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
2002 Acura RSX 4 cyl Front Wheel Drive Manual 125000 miles
I have a strange problem if im at a stop in first gear at idle, or driving in first gear with rpms below 3000 then hit the gas my vtec will not kick on, and if and when it does it cuts in and out losing power at 7000. Now on vtec honda motors they are designed to have the vtec kick on at 6000 all the way to 8000. If i drive for a couple blocks in first gear but stay above 4000 then hit the gas the vtec kicks on every single time but sometimes it cuts in and out around 7000. Now to make things more interesting none of the other gears (2nd-6th) seem to have this probem if I hit the gas the vtec kicks on and stays strong through entire powerband (6000-8000) on top of that there is no check engine light on. Now the car drives fine under normal conditions my problems dont start until i hit the gas, should i continue driving it or should i park it until problem is resolved
Dont see why you couldnt continue driving it.VTEC isnt a vital engine function for driveability. So if you are under 3000 and floor it VTEC doesnt kick in at 6000 but if you are over 4000 it will work but erratically? only in 1st gear? Might be a oil pressure problem, if the PCM doesnt see enough pressure it will turn VTEC off.doesnt explain why other gears are ok, might also be a problem with the PCM
Yes if under 3000 and floor it my vtec will not kick on at 6000 like its suppose to. and yes if above 4000 it will work but erratically. I will try and put a quart of oil in to see if that works i noticed dip stick level was a little low. my question is if there is a problem with the pcm wont the check engine light come on?
Not necessarily on an erratic problem, the PCM sees it working, then not, .Ifit works ok in all other gears, doubt if it is the VTEC solenoid, could be a PCM issue
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
