Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
2001 V8 Two Wheel Drive Automatic 95000 miles
I just paid my BMW dealer 700 dollars to repair my car. One of the problems I told him was that I observe white smoke when I start-up my car. Sometimes its a lot of smoke and sometimes its just enough to notice. It's still smoking... what could cause this smoke problem.
White smoke can indicate coolant in the combustion chamber, i would go back to the repairer and get this re checked , have a head check done this will check for exhaust gasses in the cooling system , a sure sign that there is a problem, can you tell us what was repaired for all that money? did they advise you on what was done?
As usual, I'm with Mark on this one, go back and have them prove to your satisfaction what is going on here. And by the way, what did they do for the $ they cost you, and what was the dealerships name? This issue could be a PCV valve starting to fail as the M-62 motor is extremely robust and seldom do they have coolant in the combustion chambers.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
