Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1985 Honda Civic
Auto Repair1999 Jeep Cherokee Loss...
Auto Repair1994 Other Hyundai Model...
Auto Repair2001 Oldsmobile Alero W...
Auto Repair2002 Saturn Sc2 Slave C...
Auto Repair1991 Other Hyundai Model...
Auto Repair1995 Honda Accord How T...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2001 Volkswagen Jetta alternator not charging
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Sat Jul 05, 2008 4:01 am
By stribman, Have Donated
Give Feedback | Votes: 0
Electrical problem
2001 Volkswagen Jetta 4 cyl Front Wheel Drive Automatic 90000 miles
have jetta, with 90 amp bosh alt. shop test alt it puts out 100 amps when tested, battery checks out at 235 amps cold crank, cables cleaned tightened, when car first started, volts will display 13.8 to 14 after car runs a few minutes less than 5 , voltage drops to 12.5 then to 12. not sure what steps to take now?
Find a car repair manual for your Volkswagen Jetta Repair Question.
By Advertisment,
Posted at Sat Jul 05, 2008 5:05 am
By 2CarPro Jack, Certified ASE Technician
Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669Reputation: 669 (669) Give Feedback | Votes: 80
HAve you tetsed the fuse on the battery/fuse bracket? ther should be a110 or 150 amp fuse depending on the engine size.Also test continuity from alt to fuse on big wire (black) Unfortunatly the PCM (computer) controls the alt charging in this car, so the problem may go deeper than just an alt. Also check fuse 11 behind the dash, it is part of the circuit as well
Posted at Sat Jul 05, 2008 8:17 am
cables ok, fuse 11 ok, tried a new battery, other battery showing 12.5 volts, system now charging 16.8 volts, dropped after about 10 minutes, noting that if engine raised above idle tact and insturment cluster shut off, i guess high voltage protection? after 20 min road test battery died, any sugestion on changing pcm?
Posted at Sat Jul 05, 2008 10:34 pm
By KHLow2008, Moderator
Reputation: 218.6Reputation: 218.6Reputation: 218.6Reputation: 218.6Reputation: 218.6Reputation: 218.6Reputation: 218.6Reputation: 218.6Reputation: 218.6Reputation: 218.6Reputation: 218.6 (219) Give Feedback | Votes: 12
Hi stribman,
Check if belt is slipping on pulley or faulty pulley if equipped with damper rubbers..
Posted at Sun Jul 06, 2008 6:53 am
KHLow2008 wrote:
Hi stribman,
no the belt is fine, no oil,grease dirt water ect, not hard either no belt slipage. ive have concluded it has to be something with the computer controls? and I dont look foward to that.
Posted at Sun Jul 06, 2008 8:32 am
Hi stribman,
If charging voltage keeps dropping, it could be a faulty alternator, internal rectifier or voltage regulator problem when it heats up.
Posted at Mon Jul 07, 2008 7:48 am
KHLow2008 wrote:
Hi stribman,
Yes it could be , but the alt tested ok , when checked, Im not sure what voltage they put on field to make it check, it was a shop that all they do is work on starters and alt, you would think they know there stuff, been there 30 years, would anyone know what voltage should be going to alt field from the ecm? or how to preform a check on this? I have read it is anywhere from 1.7 to 3 volts, and more than that could fry the regulator? I have had a friend read codes and got a low voltage code and one for recirculation valve fail also one for wastegate fail , could a shorted senoid cause ecm voltage drag?
Posted at Tue Jul 08, 2008 3:40 am
Hi stribman,
No, I am not doubting their capabilities, but it happens only after running the engine for a period of time before the alternator starts to provide insufficient charge.
Sometimes when contacts are bad, it shows a good reading during testing and initial running. When the circuit heats up, resistance increases and it is unable to provide the proper connection and that is when it starts to give problem.
I would suggest stripping the alternator to check for bad internal connections.
Normal ECU output voltage is 4.5 to 5 v, so it should be around that.
There are ways to test but you need to remove the ECM socket for this circuit at the same time leaving the engine wires to ECM connected. I am not sure of the wiring circuits for your car so I do not know which socket to disconnect.
You can test it by checking the voltage
Posted at Tue Jul 08, 2008 1:04 pm
KHLow2008 wrote:
Hi stribman,
thanks for the info ill check the voltage at the alternator regulator input.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
