Coolant Warning Light?
LIZZIENORMAN
  • 2008 RENAULT CLIO
  • 31,000 MILES
A light has appeared on my dashboard it looks like a bucket with a droplet of water going into it. I don't have a handbook and I do not know what this is?
I own a Renault Clio (2008) and a light has come up on my dashboard which is like a bucket with a droplet going into it. I do not have a handbook, do you know what this means?
downloaded owners manual but does not match my dashboard. Service light is also on. Any suggestions?
Friday, September 28th, 2012 AT 6:23 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,885 POSTS
It's the oil service light - (USER COMMENT)
This warning light is for the coolant level being low. It is probably time to change it here is a guide that will walk you through the process.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
and
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Saturday, February 18th, 2017 AT 4:09 PM
BRIAN KERSLAKE
  • 2001 RENAULT CLIO
Electrical problem
2001 Renault Clio Manual 41,000 miles
I have a question a dashboard light appears for what I belive is the ignition has activated to m postion and pretemperature light which causes the car to cut out upon starting up and now has not appeared for quite a long time is this natural or a concern
Saturday, February 18th, 2017 AT 4:10 PM (Merged)
DAVE H
  • 13,383 POSTS
This could just be caused by a glitch on the electrical sytem. If the light reappears have the car plugged into a diagnostic computer to locate the fault !
SARBAY
  • 2006 RENAULT CLIO
  • 4 CYL
  • MANUAL
  • 15,000 MILES
2006 Renault Clio 4 cyl Two Wheel Drive Manual 15000 miles
How can you clear the service light on the dashboard without taking it to dealer.
DAVE H
  • 13,383 POSTS
Th service dept of your local dealer will tell you how to reset the light !
TOEDIE
  • 2001 RENAULT CLIO
  • 4 CYL
  • MANUAL
  • 94,434 MILES
Electrical problem
2001 Renault Clio 4 cyl Two Wheel Drive Manual 94434 miles
Hi
I have above motor, lately I've had to press key fob button while turning on ignition just to start it,
but today I stopped went to shop and on my return (after 9 mins) she wont start at all and flashing led in dash is very rapid, I got the 4 digit code and input method but I cant slow down the flashing to put in any of the code?
I've ran out of ideas
HELP
DAVE H
  • 13,383 POSTS
If the 4 digit code is not working the car will need to be plugged into a renault diagnostic computer or equivalent to be reset.
JIMMYTHEBRIT
  • 30 POSTS
Sounds like the key might be at fault. The coded ring detects a chip in the key as you turn it. They key may have broken down inside and may require replacing. Get it checked at a renault dealer as they may have to order you a new key and recode it also
BRANNIGAN1959
  • 2002 RENAULT CLIO
  • 16,000 MILES
Attempted to defrost car this morning noticed heater was blowing cold air - when driving the vehicle the temperature gauge rose quite fast with a red warning light + stop sign showing on dash board
DAVE H
  • 13,383 POSTS
You may have frozen engine coolant. Have a tech check the vehicle
SQM
  • 6,383 POSTS
If you have no heat and the engine overheats, it could be due to low coolant level.
As the coolant needs to flow through the heater core in order for the heater to blow warm air. When the coolant is low, it will not have proper flow through the heater core, that will lead to cold air out of the vents.
And having low coolant will also not be able to cool down the engine and it will overheat.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
So, the first step would be to check the coolant level. If it is low, fill it to the proper level. Then look for any leaks.
https://www.2carpros.com/articles/coolant-leak-symptoms
Friday, February 4th, 2022 AT 12:13 PM
