Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine problem
2001 Other BMW models V8 Two Wheel Drive Manual 52000 miles
i have a 2001 bmw 540i when i gas it hard it studders at 4000 rpm for a second and then goes on. i scanned it and it gave me a code for a faulty left pre cat o2 sensor. what do you think is causing this hesitation.
there is a possibility that the pre cat sensor is causing the problem, and if it is setting a fault then it should be addressed first, we can then go about addressing the stuttering at 4000 rpms issue. BTW, what method was used for obtaining the fault code?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
