Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2002 Ford Windstar Blow...
Auto RepairSpeed.. Or Lack There Of...
Auto Repair2002 Ford Explorer Mess...
Auto Repair1998 Jeep Cherokee
Auto Repair2001 Saturn Sl1 Several...
Auto Repair1989 Isuzu Trooper Rela...
Auto Repair2004 Chevy Suburban Dra...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2001 Oldsmobile Alero Problem Starting
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Sep 06, 2008 4:42 pm
By TempeDan, New to the forum
Give Feedback | Votes: 0
Engine Mechanical problem
2001 Oldsmobile Alero 4 cyl 105000 miles
I tried starting my car and it would not turn over or crank. The lights and radio turned on though. There was also no clicking sound. I have received some advice already but my question is whether there is an area of the engine in which I should look for a loose wire? I am curious as to whether it's a wire because I just picked my car up a few hours ago from the shop. My auto had a great deal of work, and they did a complete inspection following a standard oil change and this is what was done:
1. Tune Up - spark plugs, set timing/adjust timing where applicable, and replaced the Ignition Coil.
2. Fuel Induction System Cleaning - throttle body cleaning, and fuel filter change.
3. Replaced Upper and Lower Radiator Hoses, and clamps.
4. Coolant Flush.
5. New Battery
6. Power Steering Fluid Exchange
7. Replace Front and Rear Brake Pads, Resurface Rotors, and change brake fluid.
8. Replace Spark Plug Boots.
9. Neutral Safety Switch was replaced - I was only able to start it in Neutral for the last few weeks.
After I picked the car up, it ran terrifically, like new. I drove it to the store then to my house - it started perfectly fine each time. Aside from the initial inspection the shop, naturally, test drove the vehicle before and after the work. The shop is going to pay to have the car towed back to them on Monday, but I would like to avoid the inconvenience of being deprived of transportation especially if this is a 5 or 10 minute fix.
I have received suggestions that it may be the starter or alternator, these possibilities I am aware of, if for no other reason I think that's the only things that weren't replaced (j/k). Is it possible a wire came loose near a spot where they did there work; if so could I tighten it and where might I look?
I did check the cables attached to the battery, they didn't seem loose, and the passenger compartment did have power - just no cranking or turn over. I am also trying to avoid additional costs. I had so much done on the car primarily because I just got some of my school money to conduct some necessary repairs and maintenance.
I appreciate any help. Thanks.
-Dan
Tempe, AZ
Find a car repair manual for your Oldsmobile Alero Repair Question.
Posted at Sun Sep 07, 2008 1:21 am
By rasmataz, Certified 2CarPros Master Technician
Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8Reputation: 1004.8 (1005) Give Feedback | Votes: 75
Get the battery and alternator load tested if their okay. start checking the ignition switch/park and neutral switch/relay and starter.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
