Auto Repair Forum - Ask a Question, Get a FREE Answer.
Go Back
2001 Mitsubishi Montero Transmission
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Tue Mar 04, 2008 6:26 pm |
By
Prelude2244,
New to the forum |
Give Feedback | Votes: 0 |
2001 Mitsubishi Montero 6 cyl Four Wheel Drive Automatic 64000 miles
Hi. I have a 2001 Mitsubishi Montero Limited (Full Size) Where exactly is the Transmission Drain Bolt located? I would like to do a maintenance Transmission fluid change. Can I just do a drain and refill with the Montero like what I do with our Honda Prelude and Honda CRV?
Thanks.
| Find a
car repair manual for your Mitsubishi Montero Repair Question. |
By
Advertisment,
| Find a
Posted at Sat Jun 07, 2008 10:02 am |
By
edwincas,
Likes cars! |
I am wanting to do the same to my Montero.
Have you had any luck.
Thanks
| Find a
Posted at Sat Jun 07, 2008 3:17 pm |
By
edwincas,
Likes cars! |
Thanks for the quick reply.
I drained the fluid out the bottom pan in the center of the vehicle as you advised. The fluid was rather dark which I suspected. Should I just replace the fluid thru the dipstick valve or would you recommend something different?
To be honest I am kind of confused when you mentioned transfer gear oil. I just wanted to change the trans fluid as I could feel it needed it but if there is more to it for this vehicle please let me know.
Thanks Again,
Edwin
| Find a
Posted at Sun Jun 08, 2008 7:20 am |
By
edwincas,
Likes cars! |
Thanks again for your informative reply.
Would it be best to drain all the fluid out? How would I be able to do that myself?
Also, I saw that ATF +4 is supposed to work for Mitsubishi vehicles. Would I be okay using this or should I only buy from the dealer?
How difficult is it to change the filter?
Should I be concerned at all about the transfer gear oil?
Thanks Again,
Edwin
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
