Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1985 Toyota Pickup Want...
Auto Repair2000 Ford Expedition Ab...
Auto Repair1988 Toyota Pickup Atte...
Auto Repair1999 Pontiac Grand Am W...
Auto Repair2005 Ford Expedition St...
Auto Repair2002 Saturn L200 Car Au...
Auto Repair2000 Mazda 626
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2001 Mitsubishi Montero over heating smells like burnt oil
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Jul 22, 2008 12:50 pm
By butchrgv, Have Donated
Give Feedback | Votes: 0
Engine Cooling problem
2001 Mitsubishi Montero 6 cyl Four Wheel Drive Automatic 130000 miles
I had a problem with my 2001 Mitsubishi over heating and had the radiator flushed and cleaned. The temp. gage does not go past ½ way but when I get out of the car it smells like the engine is hot and smells like burnt oil.
Find a car repair manual for your Mitsubishi Montero Repair Question.
Posted at Tue Jul 22, 2008 3:58 pm
By Service Writer, Certified 2CarPros Master Technician
Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8 (538) Give Feedback | Votes: 72
So it isn't overheating at this point?
OR still is?
Other than the burnt oil smell are there any other symptoms.
A shop can use a scanner to check the real engine temperature if it is in question or a heat gun can be used. We need to find out if there is a true overheat situation where the gauge is inaccurate or not.
Look in the area of the exhaust manifold to see if any seapages are found.
Posted at Wed Jul 23, 2008 5:44 am
[quote="Service Writer"]So it isn't overheating at this point?
After the radiator was cleaned it has not over heated, and the water level in the reservoir has not dropped.
Before the radiator I had the thermostat, fan clutch, water pump all changed, and it still over heated so we took the radiator to a shop and had it cleaned. The car runs fine not sure what else it can be.. thanks BB
Posted at Wed Jul 23, 2008 6:22 am
You need to verify the actual temp that the coolant temp sensor is telling the computer. IT may be telling it that the temp is good, when it isn't. You may be also able to ohm out the sensor versus a new one.
Check for codes in the computer and post them as well.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
