Auto Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2001 Lincoln Town Car intermittent blower
Posted at Fri Nov 06, 2009 5:41 pm |
By
jrelihan3@yahoo.com,
Have Donated |
(31) Give Feedback | Votes: 0 |
Electrical problem
2001 Lincoln Town Car V8 Two Wheel Drive Automatic 104000 miles
today the blower for the htr / ac just stopped working. After I shut the car down, checked the blower eatc fuse, it worked until the next time I got into the car. I made a short trip, no blower. About 2 hrs later, another short trip, blower worked. All seems to be well behind the cntrl panel, all indicators work, I can hear vacum actuaters working & the ac clutch cycles. would this be a cntrl module failure? maybe a relay somewhere? I don't know, thanks for any help |
Find a
car repair manual for your Lincoln Town Car Repair Question.
Posted at Fri Nov 06, 2009 6:35 pm |
By
mathiaso,
Certified 2CarPros Technician |
(292) Give Feedback | Votes: 18 |
Either the switch , the blower motor is on his way out if irratic in all setting or a bad ground at the blower motor resistor assembly.
if this happens in only one setting,then resistor may be the problem.
Most likely is the blower motor.
start doing this:
Disconnect battery negative cable from battery and properly isolate to prevent accidental reconnection.
Disengage the wire harness connectors from the retainer.
Disconnect the blower motor electrical connector.
Remove the motor cooling hose.
Remove the screws and remove the blower motor
Remove the wheel from the blower motor as follows:
Remove the push clip. Remove the wheel from the blower motor.
Blower motor cooling hose
Blower motor mounting plate
To install with the new blower.
Install or connect the following:
Wheel to the blower motor, if removed. Blower motor and securely tighten the screws. Motor cooling hose Blower motor electrical connector Wire harness retainers |
Find a
Posted at Sat Nov 07, 2009 6:28 pm |
By
Have Donated |
where is the resister for the motor located? Attached to the motor housing? |
Find a
Posted at Sun Nov 08, 2009 1:16 am |
By
mathiaso,
The resistor for motor is located under the passenger side of the dash. You must remove the lower dash insulator panel to see the resistor. The resistor is located right at the firewall so the inside screws can be difficult to access. The resistor block mounting tabs are slotted on the firewall side so you do not need to remove those screws completely to remove the resistor block.
Find a
Posted at Sun Nov 08, 2009 3:38 pm |
By
Have Donated |
natch, the thing worked till just about dark-30; when it quit, I put the fluke on the connector plug, with the black test lead grounded to the neg side of the battery; 1 wire read 11.7 & the other about .3. The blower speed selector was on "max". This was with with the ignition turned on & car not running, temp set to highest value & floor position button pushed. The schematic shows 2 wires gong to motor--1 for max & the other back roured thru thru resistor bank to the selector switch. I am about 98% sure this indicates a faulty motor. What are your thoughts? |
Find a
Posted at Sun Nov 08, 2009 4:04 pm |
By
mathiaso,
yes sir
Prior to removing a wheel that is to be reused, clean any corrosion from the blower motor shaft to prevent damage to the wheel mounting shaft.
you did a good job. |
Find a
Posted at Wed Nov 11, 2009 2:54 pm |
By
Have Donated |
I cannot get to the bottom screw w/o removing the wheel liner (it appears) there is not enough room either for my hand and/or tools. Is there a secret to getting this thing out? |
Find a
Posted at Wed Nov 11, 2009 9:17 pm |
By
RickMar,
Has a wrench in each hand! |
(185) Give Feedback | Votes: 2 |
Possibly your blower motor resistor is stuck. Turn the switch on with the a/c on high, with the engine off, then hit the blower motor resistor. The fan should start working. Resistor is located on the fire wall behind the right valve cover. Also behind the heater hose. It's about the size of a deck of cards. Put a screw driver against it and then tap the screwdriver….hopefully the fan will start !! Good Luck
Rick |
Find a
Posted at Sun Nov 15, 2009 3:31 pm |
By
Have Donated |
I am NOT a happy camper. Bought a new blower motor, hooked it up before installing and it did not work. I tapped the module behind the valve cover & the blower started woorking. When it did not work a short while later, a small tap started the blower again so it appears that the module is faulty, NOT the blower motor. now that we know what it is, what is the proper name for this thing so I can get another one. Thanks |
Find a
Posted at Sun Nov 15, 2009 4:52 pm |
By
mathiaso,
I can't see no module behind the blower moter unless it is the pcm!
Do you have a way to take picture of it? |
Find a
Goto page 1, 2 Next
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
