Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
2001 Isuzu Trooper 6 cyl Two Wheel Drive Automatic 63000 miles
I just purchased a 2001 Isuzu trooper. My question is, what is the oil pressure suppost to be? When cold it is at 85 psi, driving and at idle. Than when it's warm it drops down to about 40 psi while driving and 10 psi at idle. Is this normal? I put synthic 10w 30. What oil should I use?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
