To start need to be sure fluid level is good. Tah tprobably doesnt have adip stick. Need to get under it, witht he truck level, there is a drain adn fill plug in the pan on the trans, th efill plug is on pass side rear of the pan where it gets shallow, remove plug, fluid level is good when you pump a small amount of fluid up into this hole and it runs back out, with the engine running.If level is good, have the PCM scanned for transmission codes that may lead to a problem
