Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1999 Isuzu Rodeo Questio...
Auto Repair2003 Dodge Neon Dash Gages
Auto Repair2003 Chevy Trailblazer ...
Auto Repair1996 Infiniti Q45 Oil L...
Auto Repair1990 Ford F150 Truck Wo...
Auto Repair2001 Gmc Jimmy When
Auto Repair2003 Nissan Sentra Can'...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2001 Isuzu Rodeo Question Brake Pedal Travel
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sun Jul 13, 2008 2:46 pm
By huladick, Have Donated
Give Feedback | Votes: 0
Brakes problem
2001 Isuzu Rodeo Question 6 cyl Four Wheel Drive Automatic 210,00 miles
This Rodeo has 4 wheel ABS. Sometimes while stopping, the pedal will go to the floor. Then I pump the pedal and the wheels lock up and stops very quickly. After that, everything acts normally for a while and it will do it again.
I cannot get it to repeat itself in the presence of a mechanic. Hard to troubleshoot when it won't fail all the time. Thanks for any help.
Find a car repair manual for your Isuzu Rodeo Question.
Posted at Sun Jul 13, 2008 3:10 pm
By merlin2021, Certified 2CarPros Master Technician
Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1 (633) Give Feedback | Votes: 51
Any dash lights come on when it happens?
Posted at Sun Jul 13, 2008 5:03 pm
No dash lights. Just the pedal going to the floor.
Posted at Mon Jul 14, 2008 6:06 am
The combination valve may be defective if the dash light didn't come on during the problem. If this is bad pressures between front and rear is affected, and pedal hieghts will change until the valve centers.
Posted at Mon Jul 14, 2008 8:34 am
Thanks Merlin...
If the combination valve was bad, would I still feel brakes at either front or rear ? When my problem happens, I have no brakes at all until I pump it. Then they lock up.
Posted at Mon Jul 14, 2008 1:51 pm
If the combination valve is bad, we can test it! Open a bleeder at the rear and have a friend turn the key on wait until the warning light goes out, open bleeder, push pedal down slowly and hold, close the bleeder, did the warning light go on? Then repeat this test at a front bleeder, if thelight does not go on, valve is bad! The other possibilty is contaminated fluid, if tranny or motor oil was added to the master cylinder, you will also have these problems, and it will get worse until all parts made of rubber are replaced, oil swells the seals and softens them. Test the fluid by removing some from the master and putting it in a cup of water. Swirl it, the color should turn milky white, with NO OIL beads in it.
Posted at Thu Aug 07, 2008 1:25 pm
By cagriff2, New to the forum
Correction: It has ABS light coming on when this happens. EGR valve is bad/going bad, Could this have anything to do with it?
Posted at Fri Aug 08, 2008 12:43 pm
Not likly that the EGR has anything to do with it. Read the codes like this...post em and we go from there. OK" ANTI-LOCK -2001 Isuzu Rodeo LS
Page 1 of 1
RETRIEVING DIAGNOSTIC TROUBLE CODES
Using Scan Tool
Connect scan tool to Data Link Connector (DLC). See Fig. 1 . Following scan tool manufacturer's instructions, select appropriate mode to view DTCs. If DTCs retrieved, see DIAGNOSTIC TROUBLE CODE INDEX table. Identify DTC and perform specified diagnostic procedure. See DIAGNOSTIC
TESTS . After repairs, DTCs must be cleared. See CLEARING DIAGNOSTIC TROUBLE CODES . If no DTCs are retrieved, diagnose by symptom. See SYSTEM TESTS .
Using ABS Warning Light
1.When ABS warning light remains illuminated, EHCU will store DTCs and disable ABS system. If DTCs are not displayed, wiring harness from EHCU to ABS warning light may be disconnected. Check and repair harness if necessary. 2.Ensure ignition is off and brake pedal is released. Using jumper wire, jumper Data Link Connector (DLC) terminals No. 4 and 12. See Fig. 1 . Turn ignition on. DTC is displayed by flashing ABS warning light. See Fig. 2 . 3.A stored DTC is displayed 3 times, each being separated by a 3.2 second pause. If multiple DTCs are set, second DTC will follow after first DTC is displayed a third time. All DTCs contain 2 digits. First digit of DTC is identified by a series of .4 second flashes. After a 1.2 second pause, second digit of DTC will follow in another series of .4 second flashes. If no DTCs have been stored, ABS warning light will repeat DTC 12 (system normal). 4.If DTCs are retrieved, see DIAGNOSTIC TROUBLE CODE INDEX table. Identify DTC and perform specified diagnostic procedure. See DIAGNOSTIC TESTS . After repairs, DTCs must be cleared. See CLEARING DIAGNOSTIC TROUBLE CODES . If no DTCs are retrieved, diagnose by symptom. See SYSTEM TESTS .
Fig. 1: Identifying Data Link Connector Terminals
Courtesy of ISUZU MOTOR CO.
Fig. 2: ABS Diagnosis Using ABS Warning Light Courtesy of ISUZU MOTOR CO.
© 2007 Mitchell Repair Information Co., LLC.
http://www.ondemand5.com/mric/common/asp/printart.aspx
8/8/2008
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
