We are the Auto Repair Experts!
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2001 Honda Odyssey CAR ALARM WON'T STOP AND BATTERY IS LOW
Posted at Sun Nov 15, 2009 4:01 pm |
By
bonson,
Likes to hang around! |
(10) Give Feedback | Votes: 0 |
Electrical problem
2001 Honda Odyssey 6 cyl Front Wheel Drive Automatic 100000 miles
Hi
My Honda odyssey van was sitting for about 2-3 weeks without being moved. I thought I would go out and start it because it had been unused for so long.
The remote would not open the door, in fact, the alarm started to go off when I tried the remote. I then opened the door manually but the alarm would still not be silent. I can tell the battery is low because the alarm sound is weak and slows when I open and close the door.
The ignition is dead because the alarm is going. Panel lights come on but are dim, clock still goes but at wrong time.
I cant jump start the battery because the car is immobile because the alarm disarms stuff.
I have Googled and tried advice like turn the key left then all the way right and that should turn the alarm off - doesn't work. I have looked for the small button meant to be at knee level to turn off the alarm - cant find it.
Not sure if it is factory fitted alarm or after factory fitted.
To cut all that story short - how do I disconnect the alarm - thanks so much.
Kim Johnson
Find a
car repair manual for your Honda Odyssey Repair Question.
Posted at Sun Nov 15, 2009 9:15 pm |
By
kng1818,
Loves to help! |
(193) Give Feedback | Votes: 4 |
When the alarm go off, is the horn honking or aftermarket siren sounds? |
Find a
Posted at Tue Nov 17, 2009 7:39 pm |
By
bonson,
It was more like a chirping sound. I think it is the horn but the battery is low.
Thanks |
Find a
Posted at Tue Nov 17, 2009 11:01 pm |
By
kng1818,
Loves to help! |
Look under the driver's side dashboard near the parking brake and brake pedal area to see if theres any aftermarket components. You could use a battery jumper or jump start the battery and try to disarm the system by pressing unlock on the remote. |
Find a
Posted at Wed Nov 18, 2009 9:14 am |
By
bonson,
Hi again
I have found out that the alarm is after factory. The remote is not Honda issue. The system closes all windows when the remote is closed.
So the noise is not the horn.
I have looked where you said and can't see anything that would indicate alarm, but I have taken 3 pics of the are and you may be able to spot something.
Thanks
Find a
Posted at Wed Nov 18, 2009 8:19 pm |
By
kng1818,
Loves to help! |
There's a couple of big wires (red) and the black wires is not factory at the right side of the picture. The aftermarket security system could be inside the kick panel just follow the red wires to see where it goes. |
Find a
Posted at Thu Nov 19, 2009 3:12 pm |
By
bonson,
Gee you are good. How you manage to notice that?
The wires go to a box under the driver seat. I didn't even know the box was there.
I have given more pics.
Will I disconnect all wires to this box?
The guy who sold this van said he did several add ons. I don't care if I lose his add ons. I only want the alarm cut, but I don't want to disarm anything that I need to get the car up and running.
If this is the alarm I suppose I will be able to hook up the box and alarm after the van has been jumped and the battery is good again.
Thanks again.
Find a
Posted at Fri Nov 20, 2009 10:02 pm |
By
kng1818,
Loves to help! |
I repair Honda cars for years and know the ins and outs of their automobiles.
The second picture you provided is a power inverter, which could drain your battery because it is hooked up directly from the battery. This device has nothing to do with your no start.
Check the following places to see if you can find any aftermarket device:
The first picture on the left side is the kick panel (gray) - remove it to see if you could find anything there...
What about the two black wires next to the red wires, where do they go?
Check the area above the two red wires... |
Find a
Posted at Sat Dec 05, 2009 3:16 pm |
By
bonson,
Sorry been so long getting back to you. I have been looking at places you mentioned but am still stumped.
I have taken more pics because I still don't know what I am looking for.
The pic with the 3 switches are all switched on. One of the switches looks like it has different wire and electrical tape which could be an add on.
The black wires seem to go in different directions.
If I follow a suspect wire what am I looking for at the end of it?
Sorry for being so stupid and I appreciate all your help. - Thanks again.
A
B
C
D
E
F
G
H
I
Find a
Posted at Sun Dec 06, 2009 9:17 pm |
By
kng1818,
Loves to help! |
The picture A- the two swtiches (black and white wires) on the left side looks like one of those is the switch to turn off the alarm. Try turning the ignition key to on and switch the switch to off and see if the alarm would turn off.
The picture E- The alarm shock sensor is on the left side (black box) if you follow the shock sensor wires you might found the alarm (black box also but bigger). |
Find a
Goto page 1, 2 Next
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
