Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1999 Isuzu Rodeo Questio...
Auto Repair2003 Dodge Neon Dash Gages
Auto Repair2003 Chevy Trailblazer ...
Auto Repair1996 Infiniti Q45 Oil L...
Auto Repair1990 Ford F150 Truck Wo...
Auto Repair2001 Gmc Jimmy When
Auto Repair2003 Nissan Sentra Can'...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2001 Honda Civic AC Problems
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Goto page 1, 2  Next
Posted at Thu Jul 17, 2008 8:33 am
By tlabhk, Likes cars!
Give Feedback | Votes: 0
Air Conditioning problem
2001 Honda Civic 4 cyl Two Wheel Drive Manual 83000 miles
I have a 2001 Civic EX Coupe 5spd and the AC doesnt work. I did some research and came accross similar threads but I didn't find them very helpful for my situation.
Here's what happens: When I press the AC button inside the car, the green light comes on, but the air coming out of the vents is the same temp (really warm). The engine idle remains the same (I saw somebody ask if it increases slightly in another thread). The condenser fan does NOT come on, however if I let the car run a while with the AC on it will spin up for about 15-20 seconds and then stop. I checked all of the related fuses and relays in the fuse box under the hood and the fuse box under the dash and they were fine (I tested the relays with a 12V source).
Also, when the AC is off and I start my car, my radiator fan doesn't spin. The only time I've seen it spin is during that 15-20 second time period when I have the AC on and the condenser fan spins. Then they both stop. Is this normal?
I did the steps to retreive a DTC that I saw posted on another thread and it didn't return anything. The recirculation indicator just turns off and stays off.
Does anybody have any idea what this could be, or what else I should check to help diagnose this problem? I'm kind of a newb (I just got this civic about a month ago) so you might have to tell me where certain things are or what they look like. Thanks!!!
Find a car repair manual for your Honda Civic Repair Question.
Posted at Thu Jul 17, 2008 11:39 am
By KHLow2008, Moderator
Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7 (179) Give Feedback | Votes: 13
Hi tlabhk,
The radiator fan would not work if the AC compressor is not working or if the fan switch has not been activated, it requires about 15 to 20 mins of runnnig from cold start.
Your compressor don't seem to be working.
If the magnetic clutch relay is faulty, it can cause power to be disrupted.
Test compressor with battery voltage and see if it works.
Posted at Thu Jul 17, 2008 3:24 pm
Thanks. This may be a dumb question, but do you know where the compressor cluth relay is on my civic? I don't see it and I can't find any good diagrams online.
Also, do you know of an easy way of getting to the wires that run to the compressor? There is so much stuff in the way I can barely even see the wires never mind reach them.
Posted at Thu Jul 17, 2008 8:50 pm
Hi tlabhk,
No questions are dumb. It is because we do not know that is why we ask.
Now you are making me dumb Wink I don't have any diagrams of this model and neither do I know of its exact location.
Check the fuse box underhood for the relay. The relays are now indicated with diagrams which I have difficulty deciphering.
If you find the relay, pull it out and test for power to the wire terminals. There should be 1 powered point at all times and 2 when ignition is turned on.
Mark the relays and try swapping them around.
Posted at Fri Jul 18, 2008 1:24 pm
Hey,
You were right, the radiator fan, condenser fan, and compressor clutch relays are all located in the underhood fuse box (I don't think they were like that on 6th gen civics). I tested them all and they all work perfectly fine.
I removed the relays and applied battery voltage to the appropriate slots the relay was sitting in and the condenser fan turned on, the radiator fan turned on, and lo and behold the compressor started spinning! Does this mean that both my compressor and compressor clutch are working and its just a simple fix such as recharging or regasing the system?
What else should I check now that I know the compressor will turn on with direct voltage applied?
Thanks for all your help!
Posted at Sat Jul 19, 2008 5:43 am
Hi tlabhk,
You haven't replied if there is power supply to the relay terminals.
If no power supply, it could be a blown main (under hood) or under dash fuse
Posted at Sat Jul 19, 2008 5:48 am
Oh, sorry about that. Yeah, there is one constant power source when the car is off, and two while the car is running at all times to all three of those relays.
Posted at Sat Jul 19, 2008 7:36 am
Hi tlabhk,
There is power supply so bridge the pressure switch and if the compressor works, it could be the switch or lack of freon in system.
If not, you need to check the activating ground which is from the ECM.
Posted at Sun Jul 20, 2008 8:20 am
Shorting the pressure switch turns on the condenser fan, radiator fan, and compressor. Is there a way I can test to see if the switch is faulty?
Thanks
Posted at Sun Jul 20, 2008 9:07 am
Hi tlabhk,
If there is enough freon in the system the pressure switch should have continuity across the 2 terminals.
Test the freon pressure first.
Goto page 1, 2  Next
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
