Welcome to our question and answer forum. We answer over
6,000 free and donated auto repair questions every
month. All you have to do to ask a question is to signup
to our forum.
Asking a question is free of charge and your question
will be answered by one of our non-certified forum users
for free. You can however elect to donate to make sure
your question gets an guaranteed and professional answer
by one of our many 2carpros certified repair
technicians.
Questions
with donations are answered as promptly as possible.
Due to the nature of car repair problems, some take
longer to solve than others. We are confident that you
will be better informed regarding your problem and will
have an good idea of what direction your repair needs to
go after we have answered it. If you have donated and
were unsatisfied with our effort we will gladly return
your donation. We help thousands of people every month
and want to help you too. Sometimes it requires some
dialog between our technicians and you to get to the
bottom of your problem. 100% of the
donation is awarded to the technicians helping you.
Engine Cooling problem
2001 Honda Civic 4 cyl Front Wheel Drive Automatic 97,000 miles
My Honda Civic has recently overheated on a couple of occasions. It is random and so therefore has me a bit confused. It has done this two times only and not again since.
The last time it did overheat I waited for the car to cool down completely and removed the radiator cover. After filling the reservior, I started the car and let it run for 20-30 minutes while watching the gauge to be sure it did not overheat. During this time I observed the tank on the radiator expecting to see the water begin to circulate after the thermostat opened. The gauge never got more than half way (no temp gradiant on the gauge) and the water eventually got hot and overflowed some from the top out of the cap opening.
It has not overheated since but I am concerned as this my wifes car.
i would check the thermostat cou ld be stickin on occasion also the coolant temperature switch and relay and its wirng harness could have a short in it causing it to stop working if moved the right way.
You refilled the reservoir, did you check for coolant loss in the radiaror?
If you are losing coolant, there ought to be a leakage somewhere and when the level is full, you won't get any overheating. It would occur once the level runs low, in radiator side.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
