Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
2001 GMC Yukon V8 Two Wheel Drive Automatic 132000 miles
MY FUEL PUMP WENT OUT AGAIN......
FOUND ANOTHER ONE OUT OF A 4WD 2000 YUKON
WILL IT WORK FOR MY 2WD 2001 YUKON?
Depends on the engine. You could call the dealer or autoparts store and check part numbers for both years, if the same then you are OK, if not then don't take a chance.
You would need to know what engine the 2000 had in it.
evrything is the same xcept one of the plugs that goes into the fuel pump itself, it was a simple rewire and evrything works...... even used old tank... it was worth the try since i found the pump for 25 bucks.... saved almost $400.00!!!!!! thanks
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
