Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
2001 GMC Jimmy 6 cyl Two Wheel Drive Automatic 78000 miles
Vehicle had blown head gaskets - mechanic repaired it, then said that the vehicle was not holding oil pressure and he would have to replace the oil pump. Does this sound right? Is this common?
Replaced the oil pump. Now there is no oil pressure when in idyl. metal in oil.
Not really. The pan simply holds the oil, and closes off the bottom of the engine. Perhaps he said the oil pump? The problem I would worry about is what caused the bad head gaskets? Coolant in the oil is not good for the bearings. If it was driven that way you are likely looking at a rebuild.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
