Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Noises problem
2001 Ford Mustang V8 Two Wheel Drive Automatic 107500 miles
Engine accessory belt squeals upon starting, have replaced idler pulley. It seems noise was coming from there. by holding a screwdiver to to bolt the noise was originating there. Idler pulley replacement did nothing to quiet the squeal. belt looks good. Belt dressing spray does not help.
What is the next step reccommended to solve this problem?
Replace the tensioner and the belt, save yourself the headaches! Also, with belt off, check the A/C pulley, make sure it spins freely, no binding or grinding!, can be the pulley bearing inside...
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
