Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2000 Dodge Truck Brake ...
Auto Repair2000 Pontiac Grand Am C...
Auto Repair2000 Chevy Venture Engi...
Auto Repair2001 Chevy S-10 Changin...
Auto Repair1998 Chevy Astro Starts...
Auto Repair2000 Dodge Intrepid No ...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2001 Ford Focus Sporadic Electrical Problem
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Sep 30, 2008 7:02 am
By danabr2002, Have Donated
Give Feedback | Votes: 0
Electrical problem
2001 Ford Focus 4 cyl Two Wheel Drive Automatic 70,000 miles
We've recently encounted a very sporadic electrical problem with our 2001 Ford Focus SE (four door). The problem has happened twice on the freeway (going 65 mph) and once at a stop light (idling). Without warning, the dash gauges zero out and the front head lights and radio go out. As dash leds go, the cruise control dash light illuminates on/off during the problem timeframe. After two or three minutes (maybe as long as five minutes), they all come back on in unison.
There does not appear to be any mechanical failure when this dilemma is happeing. The motor, power steering, etc. appear to continue functioning normally (though I am not sure about brake lights) or other subtle aspects of the car.
So far, we have had the following done by a local certified mechanic to address the issue:
1. Replaced the alternator (found charging system faulty)
2. Replaced the ignition switch (no hard evidence..just a recommendation).
3. Charging system check.
4. Full electrical inspection.
The problem however, still persists. The fact the issue is not reproducible at will is the main challenge the mechanic faces. The car is back at the shop as I write this, but I wanted to put this out there to see if anyone has any ideas?
Regards
Find a car repair manual for your Ford Focus Repair Question.
Posted at Tue Sep 30, 2008 8:35 am
By 2CarPro Ken, Certified ASE Technician
Reputation: 123.4Reputation: 123.4Reputation: 123.4Reputation: 123.4Reputation: 123.4Reputation: 123.4 (123) Give Feedback | Votes: 9
Hi, Ford had a recall on the battery cables for that car, check your cables for burned marks near the battery terminals and get back to me.
Posted at Tue Sep 30, 2008 8:36 am
By KHLow2008, Moderator
Reputation: 178.6Reputation: 178.6Reputation: 178.6Reputation: 178.6Reputation: 178.6Reputation: 178.6Reputation: 178.6Reputation: 178.6Reputation: 178.6 (179) Give Feedback | Votes: 13
Hi danabr2002,
Thank you for the donation.
The problem don't seem to be caused by the charging system.
I would say it is a bad connection somewhere causing power supply to be interupted.
I would suggest checking junction and fuse boxes connectors for overheating, looseness etc.
Does the headlights goes off no matter in low or high beam mode?
Is your vehicle equipped with DRL?
Are the speedometer and tachometer working?
All gauges stopped working or any still working normally when it happened?
Can you pleaase let me know the exact vehicle model?
Posted at Tue Sep 30, 2008 9:15 am
KHLow2008 wrote:
Hi danabr2002,
-->mechanic looking into fuse boxes for symptoms you've described. So far, nothing obvious has surfaced.
Does the headlights goes off no matter in low or high beam mode? -->The headlights seem to be controled by the ignition switch. When the car is on, the lights are always on. It's my daughter's car and I've never driven it, so I'm not sure if the headlights need to be manually turned on at night. This has happened once at night and the lights were set to low beam.
Is your vehicle equipped with DRL?--> Sorry, I do not know what "DRL" means.
Are the speedometer and tachometer working? -->they work, just not when the problem is happening. When the problem happens, all gauges zero out (analogue).
All gauges stopped working or any still working normally when it happened? -->all gauges.
I'll need to get back to you on that.
Posted at Tue Sep 30, 2008 9:32 am
Hi danabr2002,
DRL = Day Running Light. Your description means yes.
Check the battery cable as advised by Ken.
Posted at Tue Sep 30, 2008 10:29 am
Ken, I really apologize for my ignorance. My DMV papers incorrectly list this car as 2001; in fact, it's 2002 Ford Focus SE (4 Door).
Does this change anything?
Thanks.
Posted at Tue Sep 30, 2008 10:30 am
KHLow2008 wrote:
Hi danabr2002,
Hi, I really apologize for my ignorance. My DMV papers incorrectly list this car as 2001; in fact, it's 2002 Ford Focus SE (4 Door).
Yes--DRL enabled when turning on the motor.
Thanks.
Posted at Sat Oct 04, 2008 4:50 am
Just to follow up on this.
Did you check the cable and was there any fault found? Have you solved the problem yet?
Posted at Mon Oct 06, 2008 8:01 am
sometimes I have seen a battery short out internaly, If all the electrical shorts out it the battery could cause it.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
