Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
2001 Ford F350 V8 Four Wheel Drive Manual 168000 miles
I need to replace my engine it's the 7.3 What I wanted to know is do I have the clearance to remove the engine by removing the turbo or do I need to lift the cab off the frame? I looking for the best way thanks
According to Mitchell, you remove the turbo and just about everything off the front of it and it comes out the top, but they do suggest trans removal on m/t trucks first.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
