Free Car Repair Advice by Certified ASE Technicians
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2001 Ford F350 brake lights on permanently
Posted at Sat Oct 31, 2009 9:46 am |
By
skidboot,
Have Donated |
(6) Give Feedback | Votes: 0 |
Electrical problem
2001 Ford F350 V8 Two Wheel Drive Automatic 97,000 miles
I noticed the brake lights ( both rears and upper cab lights) on when I shut the truck off after a short trip ( 4 miles) towing an 8,000lb trailer. The power light on my brake controller was also on. I disconnected the brake controller, no change. I removed the fuse for the brake lights, and they remained on. Everything works fine, including the brakes. I made sure the parking brake wasn't on. The only way to get the lights to go off is to disconnect the battery. Last brake job was about 30,000 miles ago. No problems since then |
Find a
car repair manual for your Ford F350 Repair Question.
Posted at Sat Oct 31, 2009 9:58 am |
By
merlin2021,
Certified 2CarPros Master Technician |
                    (10339) Give Feedback | Votes: 136 |
Check the BOO(brake on off) switch on the pedal arm. Unplug it and test switch for proper continuity. An OHM meter will show OL when pedal is in released position, and zero ohms when pressed. If readings differ, replace the switch, if reasdings are OK inpect the wires to the switch. |
Find a
Posted at Sat Oct 31, 2009 10:23 am |
By
skidboot,
Have Donated |
I disconnected and removed the BOO switch completely, and the lights are still on! |
Find a
Posted at Sat Oct 31, 2009 10:26 am |
By
merlin2021,
Something tells me your trailer wiring needs to be looked at, you have a short to power to the brake lights...look there. |
Find a
Posted at Sat Oct 31, 2009 10:38 am |
By
skidboot,
Have Donated |
the trailer is not attached to the vehicle at this time |
Find a
Posted at Sat Oct 31, 2009 10:49 am |
By
merlin2021,
Right, but it does have a connector for the trailer light? And it's wired into your lights? right? |
Find a
Posted at Sat Oct 31, 2009 10:55 am |
By
skidboot,
Have Donated |
that's correct |
Find a
Posted at Sat Oct 31, 2009 11:07 am |
By
merlin2021,
These are the wires that most likey have the short, start there! |
Find a
Posted at Sat Oct 31, 2009 11:21 am |
By
skidboot,
Have Donated |
I disconnected the trailer lights/brake connector from the main wiring loom under the bumper and the lights are still on. I can't see any evidence of any obvious problem with the wiring from where it comes out of the loom to the back of the plug for the trailer |
Find a
Posted at Sun Nov 01, 2009 9:01 am |
By
merlin2021,
On the steering column find the connector for the multifunction switch(wiper and turn), and unplug it, tell me if the lights go out now, if so, replace multifuntion switch. |
Find a
Goto page 1, 2 Next
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
