Electrical problem
2001 Ford F150 6 cyl Two Wheel Drive Automatic 200000 miles
i have been trying to install a remote starter on my 2001 f150 v6 4.2,well trying to get a better idea on the wire harness that goes to the igniton switch,i disconnected the wire harness,now the truck won't start with the key,truck does have a transponder,and will start with the remote,and then if i put the key in the ign.switch and put the key in run mode it will stay running,now when i try to start with the key,the alarm code is flashing,which means the computer thinks the truck does not have the proper code,so help thanks coop
