Professional Automotive Experts Answering Your Questions
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2001 Ford F150 Engine ping
Posted at Fri Nov 20, 2009 5:12 pm |
By
allenteel53,
New to the forum |
Give Feedback | Votes: 0 |
Engine Mechanical problem
2001 Ford F150 6 cyl Two Wheel Drive Manual 165,00 miles
I've had this pick-up since it had 50,000 mi., just recently it has started pinging as if I was using low octane fuel, I've started using higher octane fuel,also have tried using an octane booster and just recently changed the fuel filter which helped some of the chugging issues I was having but I still have the ping, I've been told by a non proffessional that it could the timing chain,could this be a viable answer. |
Find a
car repair manual for your Ford F150 Repair Question.
Posted at Sun Nov 22, 2009 6:47 pm |
By
Jacobandnickolas,
Certified 2CarPros Master Technician |
                              (15253) Give Feedback | Votes: 120 |
It could be a timing issue. However, usually you will hear a worn timing chain. It will actually make noise in the engine. Also, usually you will get a ping when the timing is advanced. A loose chain will do the opposite.
Therefore, I would check / replace the Knock Sensor (KS). The KS is a tuned accelerometer on the engine which converts engine vibration to an electrical signal. The PCM uses this signal to determine the presence of engine knock and to retard spark timing if needed. Its goal is to keep the timing as advanced as possible for the best performance to a point right to where the engine is ready to ping.
Here is a picture of it and it's location:
I hope it is large enough for you to see. It is actually located on the rear of the driver's side head behind the steel fuel line.
Joe |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
