Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
2001 Ford Escape 4 cyl Four Wheel Drive Manual 88000 miles
I been trying to find out information on what I need to do to replace the spark plugs on my vehicle. I find some but it always refers to the V6. From what I read, it seems more labor intensive than a simple takeout put back in situation. Can I get to plugs with and extension or do I have to tear half of the motor apart to replace them.
Half hour job. Pull off the wires, use and extension and spark plug wrench. Blow out the hole with air first if possible. Set your gap at .051", putt a little anti-seize on the threads away from the electrode, treat the wire boot/connector with di-electric grease and put it back togather.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
