2001 Ford Escape have to wait 30 minutes to restart
Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Engine Mechanical problem
2001 Ford Escape 4 cyl Four Wheel Drive Manual 98000 miles
After driving and shut off engine car won't start and run with out holding accelerator down. If I wait 20 to 30 minutes before I restart the engine it runs ok.
sounds like you could have a leaking fuel pressure regulator causing your car to flood. you can check to see if the regulator vacuum hose has fuel in it, this is a tell tale that it is bad. hope this helps
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
