Engine Mechanical problem
2001 Ford Escape 4 cyl Four Wheel Drive Manual 98000 miles
After driving and shut off engine car won't start and run with out holding accelerator down. If I wait 20 to 30 minutes before I restart the engine it runs ok.
Find a
repair manual for your Ford Escape Repair Question.
sounds like you could have a leaking fuel pressure regulator causing your car to flood. you can check to see if the regulator vacuum hose has fuel in it, this is a tell tale that it is bad. hope this helps
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins.Click
here to find out more.
