Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair How Does it Work
Auto Repair Automobile Safety Inspection
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair1989 Other Chevrolet Mod...
Auto Repair1996 Ford Ranger Wiring...
Auto Repair1990 Chevy Cavalier Sta...
Auto Repair1998 Chevy Monte Carlo ...
Auto Repair2004 Land Rover Discover...
Auto Repair2003 Dodge Sx Tining Be...
Auto Repair1971 Ford F-100 Intake ...
Auto Repair More Repair Topics...
Car Repair Help by Professional Mechanics
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2001 Dodge Van STEERING BOX ADJUSTMENT
Posted at Sat Oct 31, 2009 2:46 pm
By ROADTREK, Likes to hang around!
(8) Give Feedback | Votes: 0
Steering problem
2001 Dodge Van V8 Two Wheel Drive Automatic 45000K miles
I have a lot of play in my steering box on my 2001 full size dodge van 3500 with a 4000 pound axle.What is the best way to adjust this .I went to a canadian tire store mechanic who adjusted it but now when taking a turn i have to turn the wheel back when before it would turn by itself.How can i get back to what i would consider to be a factory setting?
Find a car repair manual for your Dodge Van Repair Question.
Posted at Sun Nov 01, 2009 1:56 pm
By ch112063, Problem solver!
(67) Give Feedback | Votes: 13
Unless it has changed there is a lock nut and inner screw on the box. Loosen, tighten screw counter clockwise to loosen slightly, then tighten and recheck. Any lubrication problems in linkage could cause this. Be careful. It is inside so if no good it must be rebuilt or replaced.
Check all linkage first.
Posted at Mon Nov 02, 2009 3:22 pm
THANKS FOR YOUR REPLY.THE INTERMEDIATE STEERING SHAFT THAT ATTACHES TO THE STEERING BOX HAS A LOT OF PLAY IN IT AS WELL.THE UNIVERSAL JOINTS ARE WORN BADLY FOR SUCH LOW MILES.A NEW SHAFT FROM CHRYSLER COSTS 700.00 BEFORE TAX.IS THERE SOMEWHERE I CAN PURCHASE AN AFTERMARKET STEERING SHAFT AND A STEERING BOX IF I NEED BOTH?THE PRICE IS REDICULES.I TRIED TO LOCATE ONE WITH NO RESULTS.THANK YOU FOR AN ANSWER.
Posted at Mon Nov 02, 2009 4:38 pm
Well, if you can find a place where a van, with the same setup, has been wrecked and written off, like a salvage yard you can get one a lot cheaper. If you write Chrysler, they may give it to you for cost.
I always would call junk yards but even they know how expensive a new one is. I think that the box is so important, I would only put O.E.M. in.
My customers always bring the parts so The only thing I can tell you is call around or go to Chrysler or Dodge dealer and ask them. Don't drive it tight with improper return. Too bad it failed but it is so important. Go with a new, Chrysler reman or salvage yard that has one.
We used to put the couplers in all the time and the boxes were always part of the warranty. They did not last much more than 7 years, it depends on turning and not age or mileage. you know. Call, around. Good luck ok. If I find out, I will let you know, ok?
Posted at Tue Nov 03, 2009 7:12 am
THANKS FOR THIS.I HAVE ONE OTHER PROBLEM WHICH IS THE CRUISE CONTROL ON THE STEERING WHEEL.PRESS THE CRUISE BUTTON ON STEERING WHEEL AND THE CRUISE LIGHT COMES ON IN THE DASH BUT WHEN I PRESS THE SET BUTTON , IT WILL NOT ENGAGE THE CRUISE.COULD THE SET BUTTON NEED TO BE REPLACED OR SHOULD I LOOK FOR SOMETHING ELSE?
Posted at Tue Nov 03, 2009 5:42 pm
The switch is ok, cause the PCM has turned your lamp on, I found the speed sensor or fuse or vacuum to be the usual problem.
Common problem. Need a scanner to tell exactly what is not feeding information. If you do not have a scan tool. Start with both fuse boxes and check speed sensor and vacuum. Of course there is a clock spring and cable also neccesary for it to work in set only but the servo that keeps your speed steady goes bad also. Thats why a scan helps. Sometimes, a loose cable will turn it right off. OK no problem.
Posted at Fri Nov 20, 2009 3:02 pm
The same van as other questions you answered.
I have a faulty oxygen sensor in front of the
cat. converter and when i tried to remove it with a six point socket on a strong arm i broke my strong arm because it was frozen so bad.What would you suggest
i do to remove it?Thanks James
Posted at Fri Nov 20, 2009 6:13 pm
Spray it up with penetrating oil, and let it sit. Then get a big hammer and a punch, carefully wake it up, by hitting it from a few directions then spray it again. after an hour try it again. I would heat it up cherry red and that is the final thing. Not the o2 sensor but the flange it mounts in. that will expand it. But try soaking first, hitting without ruining the lands for the socket, put a regular wrench on it(not the open end) and start cracking it. Stubborn. A 22mm fits nice and tight. ok A larger breaker bar and socket is not as effective as a comb. wrench, and hitting its handle. sometimes. I would slam it on the flat sides, directly with a hammer only. It's ok because you can drill and heli-coil if worse comes to worse. I've used a hammer and chisel to take lugnuts on wheels that no socket fits on. Wear safety glasses and any propane heat is better then nothing.
Posted at Thu Dec 10, 2009 5:52 pm
I could use a few more horsepower in this van.Would a engine performance chip be a good way to go and could
you recomend a good one since chrysler does not sell any? REGARDS JAMES
P.S. Your answers to my previous questions were very
helpful. THANK YOU VERY MUCH.
Posted at Thu Dec 10, 2009 6:45 pm
I know chips and primary ignition changes are available, but if your mileage is slightly high and your engine itself is not as efficient, its only going to give it more fuel or timing. It may not be the best thing. I'm sure one of the other fellows can help. The people who run this site are into helping, like no other website I've been to. You, of course know how much I appreciate your thanks. Come back anytime. OK I use a little 4cylinder, and always drove like an older person, even when I was younger, just a few years ago, of course.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
