Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Suspension problem
2001 Dodge Truck V8 Two Wheel Drive Automatic 127000 miles
2001 Dodge Ram 1500 SLT 2WD. When turning left while driving I get and loud noise and a vibration coming from driver's side front wheel. The faster you go the louder. Noise is only present when steering wheel is turned left. Noise goes away when turned right. Allignment was done resently and power steering pump is new. Checked movement on both front tires when they were jacked up and passenger side front tire had slight movement. Bushings in front end aren't bad looking. What could be possible problems?
Could you describe the type of noise that was emitted and the source as close as possible?
If it is a grinding type of noise, I would suggest checking the wheel bearing free play. Check the front brake backing/cooling plate to see if they are too near the rotor and brushing against each other when turning.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
