Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1995 Jeep Wrangler Oil P...
Auto Repair1996 Honda Accord Egr Valve
Auto Repair1983 Jeep Cj7 Engine Sta...
Auto Repair2001 Chevy Blazer
Auto Repair1997 Lincoln Town Car Ai...
Auto Repair2004 Saab 9-3 Repair Ques...
Auto Repair1989 Jeep Wrangler Jeep ...
Auto Repair1996 Saab 900
Auto Repair1994 Ford Ranger Solenoi...
Auto Repair2000 Honda Civic Overhea...
Auto Repair1996 Nissan Maxima Car C...
Auto Repair1997 Jeep Wrangler Horn ...
Auto Repair1997 Other Mitsubishi Mod...
Auto Repair1996 Ford F250 Hard Star...
Auto Repair2002 Nissan Sentra Rough...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2001 Dodge Stratus Sputter in low gear after warmed up with
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Mon May 12, 2008 10:47 am
By Debbie Anderson, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
2001 Dodge Stratus 6 cyl Front Wheel Drive Manual 140,00 miles
My car printed out code for mis fire a month or so ago and at this time the car was running great in all conditions. However I immediately took it to my mechanic due we did a tune up spark plugs, wires, distrib. etc. Continued to run great within a week a mis fire code came up again. Started occassionally not idling right after warmed up. Decided due to mileage etc. would replace fuel pump, filter etc. Replaced all of the above and runs great at high speed, but in lower gear/idle only after warm up it seems to act like it was getting to much fuel (with the air conditioning on and wants to sputter die out; if you let up on fule/acceleration and turn air off it is o.k., back to mechanic who says the water? temp is not reading acurately so also replaced temp sensor, still doing it, runs much better also when tank is completely full. Now the check engine light came on and code is cad coverter, meanwhile performance is not dragging and running fine? Any ideas what to check for next. I am in the kern county area of California and was just notified that may have received contaminated gas (probably what cause the fuel pump/filter to be replaced) could there be more?
Find a repair manual for your Dodge Stratus Repair Question.
By Advertisment,
Posted at Tue May 13, 2008 1:48 pm
By rasmataz, Certified 2CarPros Master Technician
Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2Reputation: 744.2 (744) Give Feedback | Votes: 66
Continued to run great within a week a mis fire code came up again. What was the OBD2 code/s P what? See below
MISFIRE TROUBLE CODES:
This includes P0300, P0301, P0302, P0303, P0304, P0305, P0306, P0307, P0308, P0309, P0310, P0311 & P0312. The P0300 code is a random misfire code while all the other misfire codes denote a misfire problem in a specific cylinder. The last digit in the code telle a misfire in cylinder number one.
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
A Random Misfire code usually indicates a vacuum leak or bad gas.
If a misfire in a specific cylinder should lead you to check the spark plug, fuel injector and compression.
Posted at Wed May 14, 2008 6:35 am
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
