Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair Car Repair Manuals
Auto Repair How Does it Work
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Automobile Safety Inspection
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Table
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2005 Mercury Monterey Heat
Auto Repair1979 Dodge Van Engine R...
Auto Repair1992 Ford Station Wagon ...
Auto Repair1988 Ford F150 Fuel Tanks
Auto Repair1976 Ford F150 Cranks B...
Auto Repair2006 Honda Civic
Auto Repair1999 Dodge Durango Shif...
Auto Repair More Repair Topics...
Auto Repair Talk - Ask a Question, Get a Free Answer
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2001 Dodge Caravan Missfire
Posted at Mon Sep 28, 2009 11:32 am
By samhemraj, Likes to hang around!
(15) Give Feedback | Votes: 0
Engine Performance problem
2001 Dodge Caravan 6 cyl Front Wheel Drive Automatic 148000 miles
Hi
My caravan is missfire change all plus wire and still.no engine light comes on any suggestion
Find a car repair manual for your Dodge Caravan Repair Question.
Posted at Tue Oct 06, 2009 7:49 am
By Jacobandnickolas, Certified 2CarPros Master Technician
Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923Reputation: 8923 (8923) Give Feedback | Votes: 70
I'm not sure I understand. You have a misfire, no check engine light, and you replaced the plugs and wires and nothing has changed? Have you checked to make sure the injector is firing? Are you getting spark to the bad cylender? Have you checked compression in that cylender? Fuel pressure?
Posted at Wed Nov 04, 2009 4:59 pm
I have turn the key on and off three times and it is giving me code 1684 can you please let me know what is it , i have little cash and cannot afford to take it to a shop
Thanks
Posted at Wed Nov 04, 2009 5:28 pm
For Chrysler products, P1684 means the battery to the pcm(powertrain control module)has been disconnected within the last 50 start cycles. A cycle is when you start the van, run it, and then shut it.
Was the battery disconnected at any point?
Posted at Sat Nov 07, 2009 1:23 am
yes the battery was disconnected because i had to change the starter
Posted at Sat Nov 07, 2009 8:58 pm
Is the miss constant?
Posted at Mon Nov 09, 2009 3:55 pm
The van is not missing constantly only when you go over 100 km\hr and i notice that there is steam coming from the radiator cap i change it but it still happening, the gauge is reading normal ,cooling fan is working any suggestion , I kindly appreciate all you help you is giving me because of my financial situation
Once again thank you
Posted at Mon Nov 09, 2009 4:54 pm
Chances are where the overflow tube connects to the radiator may have cracked. Listen, they make a pump that will pressurize the system so you can check for leaks. You may want to try that. Also, you can get a dye to put into the radiator. Drive it from a couple days and check for a leak using a black light. THe dye will glow and you can trace where it is coming from.
I hate to say it, but the tanks they use on the radiators today are plastic. Over time they either crack or where they are crimped together they get loose and come apart. Try one of the methods I mentioned. Let me know where the leak is coming from so I can help you decide if it is repairable or if it needs replaced.
I look forward to hearing from you.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Home l Help l Privacy Policy l User Agreement l About Us l Computer Repair Question l Contact Us l Link to Us l We're Hiring l Affiliate Program
  Copyright © 1999 - 2009 2CarPros.com - Professional Mechanics Online
