Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Cooling problem
2001 Chrysler PT Cruiser 4 cyl Front Wheel Drive Automatic 105000 miles
the radiator is full of water but the overflow runs almost empty after driving 20 miles and it starts bubbling/boiling the last of the fluid out the top of the overflow and radiator is full.
Find a car repair manual for your Chrysler PT Cruiser Repair Question.
Are cooling fans comming on? If so then maybe a stuck thermostat run engine does coolant flow ie. by rad cap opening? Then shut off if top hose is hot and bottom hose cool then thermostat is stuck.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
