Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2003 Pontiac Montana Oc...
Auto Repair2002 Mercury Sable Horn...
Auto Repair1998 Chevy Lumina Radiator
Auto Repair1997 Chevy Astro Chevy ...
Auto Repair1995 Pontiac Sunfire Wh...
Auto Repair1991 Ford Taurus Engine...
Auto Repair2006 Volkswagen Passat ...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2001 Chevy Venture Brake lights
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Wed Aug 06, 2008 6:08 pm
By the_fliz1, Have Donated
Give Feedback | Votes: 0
Electrical problem
2001 Chevy Venture 6 cyl Front Wheel Drive Automatic 155000 miles
About 2 months ago my wife said that when she pressed on the brakes that the turn signal indicators on the dash came on and when she tried to use the right turn signal it flashed like it was burned out. I replaced the bulb but it still did it. I checked voltage at the bulb and everything was ok. Then it went away. She mentioned that it did it a couple of times since then, but when I went to drive her van today. I turned the lights on and the turn signal indicators came on immediately and now neither blinker, tail light or brake lights work only the middle brake light in the back window will work. If you press on the brake with the car off, the same thing happens.I checked the plugs that read the brake pedal is actuated and they seem ok and the wiring going into both tail lights looks good, does anybody have suggestions or at least an idea of where to start looking?
Find a car repair manual for your Chevy Venture Repair Question.
Posted at Thu Aug 07, 2008 6:12 am
By Service Writer, Certified 2CarPros Master Technician
Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6 (537) Give Feedback | Votes: 72
Two areas I would focus on would be if any aftermarket wiring was adding for towing, if okay, then check the multifunction switch. Sometimes just playing with the switch can cause a change in symptoms.
Posted at Thu Aug 07, 2008 11:13 am
thank you for your quick response. I don't have any towing wiring and I just got done replacing the multifunction switch. Still no go. The brake lights do now work but if I have the lights on, press on the break, and have the left side blinker going it doesn't work properly/ The brake light and the blinker dim out and alternately flash. I am assuming I have a short somewhere.
Posted at Fri Aug 08, 2008 2:26 am
Posted at Fri Aug 08, 2008 6:23 am
By ma.tremblay, New to the forum
I have the exact same issue with my 2003. Been trying to figure it out for a while.
Posted at Fri Aug 08, 2008 3:22 pm
Thank you very much for the wiring diagrams. They will be very helpful. I did find a corroded probe on the top of the drivers side lighting assembly. I swapped the two tail light assemblies around to see if the problem would move to the passenger side and when I did it the lights worked fine. I moved the drivers side assembly back to it's normal side and the problem came back. I ran to the local salvage yard and got a new one and put it in and so far so good. Hopefully that is all it was. FYI for anybody interested. The multifunction assembly and switch (the turn signal switch) cost almost 300 dollars from a dealer (apparently an auto parts store cannot order one) so if you can find one they are rather common at salvage yards because the same assembly is used on all Ventures from 95' to 05'. With removal it only cost me $60. I also got a whole tail light assembly for $30 instead of the $80 that the dealership wanted to charge me. Once again, thank you for all of your help.
Posted at Sat Aug 09, 2008 6:44 am
I sent my venture to my mechanic for an oil change and told him to try and fix the lights. They seem okay, but he wasnt there so I dont know what he did. I had previously changed the whole assemblies from salvage also. It had not worked
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
