Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair Car Repair Manuals
Auto Repair How Does it Work
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance Schedule
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Automobile Safety Inspection
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Table
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Auto Repair Test Equipment Store
Auto Repair Auto Parts
Search Website
Recent Repair Topics
Auto Repair1985 Bmw 325
Auto Repair1996 Volkswagen Jetta 1...
Auto Repair1981 Mercedes Benz 200e ...
Auto Repair1993 Chevy Silverado Tp...
Auto Repair2000 Dodge Neon
Auto Repair1990 Oldsmobile Cutlass ...
Auto Repair2002 Dodge Caravan Fuel...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Chat - Ask a Question, Get a Free Answer
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible. If you are unsatisfied with our answer we will gladly return your donation.
2001 Chevy Suburban Automatic door locks
Posted at Sat Nov 01, 2008 4:34 pm
By mike6768, Have Donated
Give Feedback | Votes: 0
Electrical problem
2001 Chevy Suburban V8 Four Wheel Drive Automatic 98,000 miles
2001 Chevy Suburban. My driver door works by pushing the lock/unlock button inside on the driver door only. My keyless option works only on the driver door. My front passenger door lock works on the driver door but not on anything else. My rear passerger doors and rear hatch aren't working at all.
Find a car repair manual for your Chevy Suburban Repair Question.
Posted at Sat Nov 01, 2008 6:04 pm
By James W., Certified 2CarPros Technician
Reputation: 286.7Reputation: 286.7Reputation: 286.7 (287) Give Feedback | Votes: 15
Can you lock and unlock "all" the doors from the driver's door?
Posted at Sat Nov 01, 2008 6:11 pm
mike6768 wrote:
Electrical problem
No, only the driver door its self. The front passenger doors will lock/unlock the driver door, but will not lock/unlock the its self. And again the two rear and rear hatch don't do anything.
Posted at Sat Nov 01, 2008 8:26 pm
Everything points to the "body control module". I can't believe you would have 3 bad switches or 3 bad actuators or a combination there of. My cut and paste is down, but if you have access to a fax I can send you a wiring diagram.
Posted at Sun Nov 02, 2008 9:29 am
mike6768 wrote:
mike6768 wrote:
Electrical problem
Body Control Module, Where is that located at?
Fax#360-944-3019
Posted at Sun Nov 02, 2008 5:25 pm
Mike, there are 3 different lock systems used in your suburban. One is ruled out because you have remote entry. Narrowing down the remaining two. Do you have a lock switch on the driver's door control that will disable the rear door lock systems? Also, on your keyless remote, if you push the button "once" does it unlock the driver's door only and have to push it again to unlock "all" the doors? It may not work that way now but, is that the way it is supposed to work?
The body control module is under the left side of the dash by the steering column.
Again, if you have access to a fax, I'll send you diagrams so you will know what I'm talking about. It may just be a relay and not the BC module.
One more thing, if you try to lock or unlock the right rear door from the driver's door, do you hear anything from the RR door?
Posted at Sun Nov 02, 2008 9:52 pm
No, there isn't anything on the drivers door to disable the rear locks. As far as the keyless. Yes, pushed once will lock and unlock the driver door. Before the my problem started, yes a second push would unlock the rest of the doors. One other thing it may or may not be cause of the problem, but I was haveing problems with my battery around the time the lock problem started. I have since replaced the battery and no more problem with starting my vehicle. Could there be a problem with the automatic lock needing to be reset? My fax is #360-944-3019. Thanks
Posted at Mon Nov 03, 2008 1:48 pm
Disconnecting the battery will not affect your lock operation. As far as reseting or re-programing the system, the reciever is getting the signal from the remote because it will open the driver's door, so that part is ok. Everything points to a bad BC module. Faxed diagrams are on the way.
Posted at Sat Nov 22, 2008 11:56 am
By djrocker1007, New to the forum
Hey there Bud, Did you ever get a fix to this problem? I have one coming to my shop today for the same problem and will let you know the outcome.
David W. Houston, TX / Intensive Care Auto
mike6768 wrote:
Electrical problem
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Reparacion Del Coche l We're Hiring l Affiliate Program
  Copyright © 1999 - 2009 2CarPros.com - Professional Mechanics Online
