Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Transmission problem
2001 Chevy Silverado 6 cyl Two Wheel Drive Automatic 100223 miles
I just got my transmission rebuilt and professionally installed but now it won't start
the first thing to do is check for fuel pressure, spark & injector pulse, also do a scan to check for any fault codes.Start here. And if it will not even crank over have the transmission isolator switch checked for a fault and adjustment.
I DROVE THE TRUCK TO THE TRANSMISSION SHOP BUT IT WOULDN'T GO ANY HIGHER THAN 2ND GEAR (AUTO TRANSMISSION). MY POINT IS THAT THE TRUCK HAD NO PROBLEM STARTING. THE TRANNY GOT REBUILT AND INSTALLED BUT IT WON'T START NOW. IS THERE A SENSOR ON THE TRANNY FOR PARKING THAT MIGHT BE DAMAGE AND THEREFORE THE TRUCK WON'T START?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
