Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Auto Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Car Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How to Use Test Equipment
Auto Repair Manual Car Maintenance Information
Vehicle Repair Service Engine Soon Light
Vehicle Repair Car Parts and Equipment Store
Vehicle Repair How Does it Work?
Vehicle Repair Safety Inspection
Auto Repair Manual Online Car Repair Manual
Vehicle Repair Smog Test Preparation
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2002 Buick Rendezvous C...
Auto Repair1992 Ford Taurus Headli...
Auto RepairPolitical Request
Auto Repair1992 Honda Accord
Auto Repair1996 Dodge Ram Diagnost...
Auto Repair1999 Dodge Ram Dashboard
Auto Repair1988 Volvo 240 Door Chi...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2001 Chevy Cavalier BCM or ECM or???
Welcome to our question and answer forum where over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Wed May 07, 2008 6:28 pm
By xertechx, Have Donated
Give Feedback | Votes: 0
Computer problem
2001 Chevy Cavalier 4 cyl Two Wheel Drive Automatic 60000 miles
I bought a relocation harness to ease the install of my aftermarket stereoin a 2000 cavalier. It was pretty straight foward, just hook up the colors together and go. I went to test the stereo and I realized the new deck was not turning on and the old stereo was still on. After hardwiring the stereo to the battery, i knew the stereo wasnt the problem. So i took a meter across the black and red wire from the relocation harness and found the red wire did not show 12v, but the yellow acc wire did. So (looking back now) being an idiot i just hooked up the red wire from the stereo to the yellow (data wire?) on the harness and the stereo turned on, but still not working right. So i took the redwire from the harness and hooked it up to the yellow wire and voila, it worked, the relays on the harness kicked on and the new stereo had full control off the speakers. I put the dash back together and went to turn on the car to back it out and it would not start. It would turn on for about a second and then shut off. I tried to do the on 10 min on,off ,on 10min,off,on 10min and that did not work. I checked all the fuses under the hood and the nearest related fuses in the door and found nothing. I swaped the relay with the ac relay and that did not fix it either. I can here what i would imagine is the fuel pump turning on, but not getting any luck here. The car has about and 1/8 tank of gas but i dont think this is the problem considering i drove it the same day. I spoke to the harness manufacturer and they said i was supposed to run a new fuse for the red wire and not hook it up to the yellow wire (now they tell me).
Find diagnostic tools, replacement parts or locate a car repair manual for your Chevy Cavalier Repair Question.
By Advertisment,
Posted at Thu May 08, 2008 7:02 am
By Buzzsaw, Tech level 7
Reputation: 215.4Reputation: 215.4Reputation: 215.4Reputation: 215.4Reputation: 215.4Reputation: 215.4Reputation: 215.4Reputation: 215.4Reputation: 215.4Reputation: 215.4Reputation: 215.4 (215) Give Feedback | Votes: 12
xertechx wrote:
Computer problem
I would say you still have something wired wrong, red isnt always power because I believe its orange use a test light to find your power and ground and ign on power, if you had the doors and stuff open to long you may have ran down the battery
Posted at Thu May 08, 2008 7:13 pm
I would agree, but i put the car back to stock, and it will start for a second then shut off. I was told running voltage to the yellow wire is bad. I guess im more curious what module or part this yellow wire is connected to so i can replace it and hope that it starts. Any help would be great, i cant afford a mechanic right now but if someone has any info that would help out it would help me alot, i am desperate here.
Posted at Sat May 10, 2008 8:49 pm
By wildfirev9, Have Donated
If you haven't yet, I would start by disconnecting the battery for a minute then (after hooking it up) try to start it, then go thru the restart sequence only waiting 15 minutes between start attempts instead of 10. These pcm's are very good at relearning. Still sounds you tripped the anti-theft. Good luck, VIC
Posted at Wed May 14, 2008 11:31 am
I have tried that also... I just need to know if the yellow cable for the stereo is related to the BCM in anyway i guess
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
