Car Repair Forum - Ask a Question, Get a FREE Answer.
Go Back
2001 Chevy Astro Chevy Astro Brakes and Turn Signals; Camsh
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Fri Jun 27, 2008 8:33 am |
By
jerehtr,
Likes cars! |
Give Feedback | Votes: 0 |
Electrical problem
2001 Chevy Astro 6 cyl Two Wheel Drive Automatic 85000 miles
Hi, I have a 2001 Chevy Astro with 85000, and I have two problems. First, I have had a recent issue with the turn signals not blinking when braking. That happened to me this morning. Second, I had an error code which came up when my Service Engine Soon light came on. The code is P0341, and it says, 'Camshaft Position Sensor A - Bank 1, CKT Range/Perf'
Anyone know what to make of either of these issues?
Thanks, J
| Find a
car repair manual for your Chevy Astro Repair Question. |
By
Advertisment,
| Find a
Posted at Fri Jun 27, 2008 10:13 am |
By
jdl123,
Tech level 3 |
(14) Give Feedback | Votes: 0 |
Are you saying the turn signals work fine when you don't step on the brakes?
The brake lites and turn signals use the same voltage circuit, just not at the same time. That circuit is controlled by the turn/hazzard switch. When you engage the turn indicator switch, it kills the brake lite on that side only.
| Find a
Posted at Fri Jun 27, 2008 11:10 am |
By
jerehtr,
Likes cars! |
Yes, I am saying that the turn signals just stay in the 'on' position when hitting the brakes.
thanks,
Jeremy
| Find a
Posted at Sat Jun 28, 2008 7:50 am |
By
jdl123,
Tech level 3 |
In the rear, the brake lites and turn signal use the same bulb fillament, they can't work at the same time.
When you use the turn signal lever for a left turn, you won't have a brakelite on the left side, you should have turn signal, though. You will still have brake lites at the high-mount brake lite and brake lites on the right side.
Maybe I misunderstood your question, somehow?
| Find a
Posted at Sat Jun 28, 2008 10:08 am |
By
jerehtr,
Likes cars! |
I think I didn't communicate it well.
My signals don't blink, but just light up when applying the brake pedal. Otherwise, when I am coasting or hitting the gas pedal, they blink like they normally should. This problem happened just yesterday on the way into work. Any thoughts? Could it possibly be that one of the bulbs is going (or is already shot?)?
| Find a
Posted at Sat Jun 28, 2008 12:13 pm |
By
jdl123,
Tech level 3 |
Are you saying none of your turn signals work, front or back, when step on the brake?
You may have to check the turn/ hazzard switch.
| Find a
Posted at Sat Jun 28, 2008 12:17 pm |
By
jerehtr,
Likes cars! |
yes, the arrow stays lit up, but it doesn't blink when I brake.
Otherwise, it seems to blink just fine.
thanks!
Any thoughts on the error code P0341?
Do I just have to replace the camshaft position sensor?
thanks...
| Find a
Posted at Sat Jun 28, 2008 12:57 pm |
By
jdl123,
Tech level 3 |
Looks to me like your going to have to check the circuits at the turn/hazzard switch.
As far as the cam sensor, that's a hall switch, three wires, ref voltage, ground, signal. I'd check those before I did anything else.
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
