Auto Repair Talk - Ask a Question, Get a FREE Answer.
Go Back
2001 Cadillac Deville 2001 DeVille ABS, Brake,Traction Warn
Posted at Sat Apr 19, 2008 7:33 pm |
By
Jimmiez,
Have Donated |
(15) Give Feedback | Votes: 0 |
Brakes problem
2001 Cadillac Deville V8 Front Wheel Drive Automatic 32000 miles
The ABS, Brakes, and Traction warning lights had come on occasionally, but now remain on all the time. It's never one, or two of the lights, but always all three that stay on. I don't know how, nor have equipment to retrieve codes. What would be the troubleshooting steps I need to take to isolate the problem? Thanks....
| Find a
repair manual for your Cadillac Deville Repair Question. |
By
Advertisment,
| Find a
Posted at Mon Apr 21, 2008 5:06 pm |
By
Jimmiez,
Have Donated |
Thanks for the info. I'll pursue that direction.
| Find a
Posted at Fri Apr 25, 2008 6:44 pm |
By
Buzzsaw,
Tech level 7 |
          (214) Give Feedback | Votes: 11 |
| Jimmiez wrote: | | Thanks for the info. I'll pursue that direction. |
also Service Writer he needs to ck the brake fluid it can cause this prob, pads may be warn enough to have it come on
| Find a
Posted at Mon Apr 28, 2008 6:15 pm |
By
Jimmiez,
Have Donated |
Thanks Buzzsaw, fluid and pads are fine...had them checked about 4 months ago. No audible bearing noise. I did a visual on the leads and they look fine. Removed/cleaned connector terminals at each wheel with LPS in case they may have been dirty. No help. Will a scan determine which sensor, if any is the problem?
| Find a
Posted at Tue Apr 29, 2008 9:04 am |
By
Buzzsaw,
Tech level 7 |
| Service Writer wrote: | | A scanner that is capable of reading the wheel speed input will. It will show what the computerfor that system is being told by the speed sensor. |
scan your codes, off and down on your mode button with the key in the on position, get a peice of paper to write them down, look in the message center for the codes, like Service Writer says it might be the VSS or a wheel sensor
| Find a
Posted at Tue Apr 29, 2008 6:16 pm |
By
Jimmiez,
Have Donated |
Thanks Service Writer and Buzzsaw.
Autozone scanned the engine codes and there were none. This issue never showed the MIL, just the three warning lights. The 3 lights stay on when the vehicle is stopped (obviously all wheels going the same speed)...is it correct to assume there is NO signal from one of the wheel sensors? If so, can wheel sensors be jumpered one at a time to determine which may not be sending a signal? How? As I said earlier, I don't have a scanner. Where I'm going here is to determine if I can diagnose which sensor is bad and can I (a better than average though untrained mechanic) replace the wheel bearing assembly?
| Find a
Posted at Wed Apr 30, 2008 6:52 pm |
By
Buzzsaw,
Tech level 7 |
| Jimmiez wrote: | Thanks Service Writer and Buzzsaw.
Autozone scanned the engine codes and there were none. This issue never showed the MIL, just the three warning lights. The 3 lights stay on when the vehicle is stopped (obviously all wheels going the same speed)...is it correct to assume there is NO signal from one of the wheel sensors? If so, can wheel sensors be jumpered one at a time to determine which may not be sending a signal? How? As I said earlier, I don't have a scanner. Where I'm going here is to determine if I can diagnose which sensor is bad and can I (a better than average though untrained mechanic) replace the wheel bearing assembly? |
scan your codes like I asked to on the last reply, caddies dont need a scan tool, they have self diagnostics. If lights are on you have codes
| Find a
Posted at Sun May 11, 2008 6:24 pm |
By
Jimmiez,
Have Donated |
Thanks, Buzzsaw. The DIC doesn't show any messages that any systems are malfunctioning. The brakes work fine, although I've not been in any driving conditions that would activate the ABS. What if the brake control module itself is bad and sending erroneous signal, then the ABS and Traction Control systems drop out because the brake warning light is on?
| Find a
Goto page 1, 2 Next
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
