Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Auto Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Car Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How to Use Test Equipment
Auto Repair Manual Car Maintenance Information
Vehicle Repair Service Engine Soon Light
Vehicle Repair Car Parts and Equipment Store
Vehicle Repair How Does it Work?
Vehicle Repair Safety Inspection
Auto Repair Manual Online Car Repair Manual
Vehicle Repair Smog Test Preparation
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1998 Honda Civic Troubl...
Auto Repair1997 Toyota Camry
Auto Repair1997 Ford Taurus Leak
Auto Repair1995 Mazda 626 A/c
Auto Repair2003 Chevy Cavalier Iat...
Auto Repair1994 Chevy Truck 6.5 Tu...
Auto Repair2003 Chevy Trailblazer ...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2001 Buick Century ignition
Welcome to our question and answer forum where over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Sun Jul 06, 2008 4:05 pm
By golfido, Have Donated
Give Feedback | Votes: 0
Electrical problem
2001 Buick Century 6 cyl Front Wheel Drive Automatic 88,000 miles
I get a 1374 code. It is an ignition problem. Car is hard to start then runs rough when it does run. However it runs great at times. Is this code the coil pack?
Find diagnostic tools, replacement parts or locate a car repair manual for your Buick Century Repair Question.
By Advertisment,
Posted at Mon Jul 07, 2008 6:34 am
By jdl123, Tech level 3
(11) Give Feedback | Votes: 0
It's a crank sensor code. My information shows two crank sensors. I'd check the 7x sensor first, that sends the signal to the ignition module. Might be the sensor--wiring circuit or connector.
You might also check the other one.
Posted at Mon Jul 07, 2008 11:00 am
Thank you for responding. I am in the middle of replacing the crank sensor behind the crankshaft pully. It looks like a 1/4 moon. The other one is cylinder like. Where does that one go?
Posted at Mon Jul 07, 2008 11:46 am
You should have tried to do some testing, first. The code won't tell you if the problem is the sensor-- wiring circuit-- connector or whatever.
The magnetic reluctance crank sensor may be on the back side of the engine block, down low. The wiring harness goes to the ignition module. The ignition module is under the coil pack. There should be two wiring connectors on one end of the module, the smaller connector should be for that crank sensor, you can follow the wiring. The primary colors are purple and yellow.
Posted at Tue Jul 08, 2008 2:57 am
Thanks again for responding. I am not that swavy when it comes to electrically testing components. My father in law, since retired from 30plus years of automotive repair, questions the fuel pump. He states that pressure could be low causing misfire codes. I will check pressure. Do you know the proper fuel pressue for such an engine. 3100 v6 buick centuy, 2000. I like that idea also due to the fact that it kinda runs only when gas pedal is pumped while engine is turning over. Then will kinda run only at higher rmps. Once at idle she dies.
Posted at Tue Jul 08, 2008 3:17 am
By bthood, Likes cars!
Key On Engine Not running 52 to 59 PSI.
I am not certain about Buick, but I had a 3.9 Liter Ford that called for 35 PSI with the key on/ engine off. I found 30 (+/-) PSI at the port. THis engine would not start or run. When I replaced the pump, it run like a new one. I hope this helps.
Brian
Posted at Thu Jul 10, 2008 3:21 am
Are we having fun yet!? 2 New crank sensors, 1 new camshaft sensor, 1 new 02 sensor, 1 new fuel pump. same problem. Only thing left is the ignition module under the coil pack. If not that, cumputer?
Posted at Fri Jul 11, 2008 10:36 am
By dennyp, Tech level 7
Reputation: 100.2Reputation: 100.2Reputation: 100.2Reputation: 100.2Reputation: 100.2 (100) Give Feedback | Votes: 5
It's most likely a bad ignition module or a coil pack that is arcing to the module.
Posted at Fri Jul 11, 2008 12:48 pm
It was the ignition modual. Runs great! still somewhat shaky tranny, but rolling.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
