2001 BMW 320 parking sensors and manual boot lid button
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
2001 BMW 320 6 cyl Two Wheel Drive Manual 40000 miles
hi,the parking sensors are not working or is the manual button for the rear boot lid.could someone maybe help me out many thanks ian c
Ian! Inspect the wiring harness at the right side of the boot lid to the "tub". Pull the accordion boot loose and throughly inspect the wires inside. Then the parking sensors should be subjected to a short test and this will require either the equipment the dealer uses called a Group Tester One (or GT-1) or Autologic software. The newer BMW cars are electronically sophisticated and many things regarding repairing them are limiting to the "do it yourself" folks out there.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
