Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2001 audi at qt battery replacement
Welcome to our question and answer forum. We answer over 6,000 free and donated auto repair questions every month. All you have to do to ask a question is to signup to our forum.
Asking a question is free of charge and your question will be answered by one of our non-certified forum users for free. You can however elect to donate to make sure your question gets an guaranteed and professional answer by one of our many 2carpros certified repair technicians.
Questions with donations are answered as promptly as possible. Due to the nature of car repair problems, some take longer to solve than others. We are confident that you will be better informed regarding your problem and will have an good idea of what direction your repair needs to go after we have answered it. If you have donated and were unsatisfied with our effort we will gladly return your donation. We help thousands of people every month and want to help you too. Sometimes it requires some dialog between our technicians and you to get to the bottom of your problem. 100% of the donation is awarded to the technicians helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Thu Mar 01, 2007 11:14 am
By fogsmith, Likes cars!
Give Feedback | Votes: 0
Hi all - I have just replaced my battery and now my car is throwing p0300 p0301 p0302 codes. These are misfire codes and I was wondering if I really have to go to the local stealership and have my ecu reset with the proper idle settings, etc.
Many thanks,
Jeff
Find diagnostic tools, replacement parts or locate a car repair manual for your Audi Quattro Repair Question.
By Advertisment,
Posted at Thu Mar 01, 2007 11:46 am
By Bruce Hunt, Certified 2CarPros Master Technician
Reputation: 413.7Reputation: 413.7Reputation: 413.7Reputation: 413.7Reputation: 413.7Reputation: 413.7Reputation: 413.7Reputation: 413.7Reputation: 413.7Reputation: 413.7Reputation: 413.7Reputation: 413.7Reputation: 413.7Reputation: 413.7Reputation: 413.7Reputation: 413.7Reputation: 413.7Reputation: 413.7Reputation: 413.7Reputation: 413.7Reputation: 413.7 (414) Give Feedback | Votes: 39
Is the car running a bit rough? How replaced the battery? I am thinking in the battery replacement that you may have had a couple of plug wires loosened or strained to the point they are weak. You can clear the codes by pulling the main fuse under the hood and waiting a minute to reconnect.
Posted at Thu Mar 01, 2007 11:51 am
Bruce - thanks for your reply.
A bit of background - my MAF sensor has been throwing me a p0171 code and have cleaned it a bit - just ordered a new one. Would I be incorrect in thinking a fouled up MAF could cause the cylinders to misfire or is that a result of lack of power from the battery due to a bad ground, etc.
Best,
Jeff
Posted at Thu Mar 01, 2007 12:13 pm
Bruce, as far as running roughly - after turning the key the battery meter will go from 14 to about 12 and eventually after a few seconds dies. After restarting another 2 or three times the car will start and idle roughly then smoothly. As far as running roughly once it begins to idle smoothly it runs fine.
Thanks again...
JJS
Posted at Thu Mar 01, 2007 1:47 pm
Good grounding at all points is essential. I am concerned about the voltage dropping from 14 to 12. Check out the grounds first. Then have the alternator checked. The internal voltage regulator could be starting to go.
My question should not have been How but who replaced the battery?
Posted at Thu Mar 01, 2007 2:48 pm
Bruce - my new battery was installed by my mechanic who specializes in imports.
I have ordered a new MAF sensor that I can install myself and I am hoping that will cease the P0171 code I am getting.
As far as the P0300, P0301, and P0302 I will have the mechanic check the ground and test the alternator.
As far as getting my ECU reset I am hearing conflicting things from lots of my friends and on the internet. So, when replacing a battery for an Audi or other German import does the car have to go back to the dealership to have the idle codes and other info reprogrammed??
Thanks again for your prompt responses as I am learning quite a bit about my A4.
Jeff
Posted at Fri Mar 02, 2007 9:52 am
Actually the cars computer will learn that on it own again unless there is a sensor that is not giving it correct information to work with.
Posted at Mon Mar 05, 2007 8:32 am
By ddcyr40, Tech level 1
Reputation: 21.3 (21) Give Feedback | Votes: 1
i had my battery replaced in a 2000 vw passat v6 by walmart and nothing happened as a result. works fine, no codes or anything. i know before i replaced it, my power windows were acting funky...
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
