Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Steering problem
2001 Acura EL 4 cyl Two Wheel Drive Automatic 133000 miles
Steeing fulid is over flowing from the resouvior
Its over filled, if you look at the dip stick on the cap it should show a cold level and a hot level. The fluid will be higher in the reservoir when the car is warmed up.
______________________
Check out some Eurobz Parts
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
