Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Computer problem
2001 Acura CL 6 cyl Front Wheel Drive Automatic 179000 miles
Yesterday my Check Engine and TCS lights came on together. Idle seems OK, but some stumble on acceleration. Have been using mid grade gas for awhile. Any ideas??
The check light indicates something is wrong with the engine management system. TheTCS may or may not be related to the problem so it is best to get a scan to find out which item is not funtioning as required.
the tcs light is just a byproduct of the check engine light. the tcs' function relies on the engine and cannot operate when the engine is not running correctly. most common cause of this combination is a misfire.
when was your last tune-up?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
