Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Heater problem
2001 Acura CL 6 cyl Front Wheel Drive Automatic 111000 miles
We just replaced the battery in our Acura and now the heater fan/ won't quit running. We can change the temp, but not turn on the A/C. Tried simply shutting off with the control and that doesn't work. Had to pull the fuse to gt it off.
Hello, if I understand you correctly, the blower fan for the AC/Heat will not shut off unless you pull the fan fuse? Have you checked the codes? Auto Zone and O’Reilly’s does this for free. I think it may be the blower motor resistor. "B" in the pic
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
