Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1999 Ford Expedition
Auto Repair1994 Dodge Caravan Cutt...
Auto Repair1995 Chevy Blazer Egr V...
Auto Repair1987 Mazda B2200 Signal...
Auto Repair1984 Toyota Pickup Acts...
Auto Repair1997 Ford Escort
Auto Repair1992 Nissan Sentra Car ...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2000 Toyota 4Runner 4 wheel drive
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Aug 22, 2008 9:47 pm
By brad@fone.net, Have Donated
Give Feedback | Votes: 0
Transmission problem
2000 Toyota 4Runner 6 cyl Four Wheel Drive Automatic 112000 miles
I hope you can help. I just purchased the 4 runner listed above. I live in Colorado but it came from Florida.. Long ways from home. Anyway, Car runs perfect but I don't think it has been engaged in 4 wheel drive for a long time. When I press the button on the side of the lever, the lights just blink and do not engage. Sometimes they actually do engage and when I try to depress the button the lights blink again and it will not disengage. I have check all connection to the transfer case and checked oil in the transfer case. I do not feel it is electrical but maybe the engagement mechanism has failed?
Please help...........
THANK YOU!
Find a car repair manual for your Toyota 4Runner Repair Question.
Posted at Sat Aug 23, 2008 4:48 am
By merlin2021, Certified 2CarPros Master Technician
Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1 (633) Give Feedback | Votes: 51
OVERALL SYSTEM CHECK 1. Raise vehicle off ground and support with jackstands, so all 4 wheels can rotate. Start engine and place transfer case shift lever in "L" position on Land Cruiser, "L4" position on Tacoma, and 4WD position on 4Runner. On Land Cruiser, turn differential lock control switch to "RR", on all other models turn differential lock control switch on. Ensure indicator light turns on. Go to next step. 2. If light indicator light is blinking, rotate tires to engage differential gears. Turn differential lock control switch off, and ensure indicator light turns off. Go to next step. 3. Turn differential lock control switch on. Locate 4WD control unit. See Fig. 1 , Fig. 2 or Fig. 3 . With wheels turning at 5 MPH, measure voltage between 4WD control unit terminals No. 2 and 3 by backprobing connector. See Fig. 4 . Voltage should be 0.5 volt or less. If voltage is not as specified, check wiring harness for short to voltage. See WIRING DIAGRAMS . Repair as necessary. Turn differential lock control switch off. Stop engine and lower vehicle. Fig. 4: Identifying 4WD Control Unit Terminals Courtesy of TOYOTA MOTOR SALES, U.S.A., INC.
[img]
DIFFERENTIAL LOCK CIRCUIT 1. Ensure battery voltage is 10-14 volts. Disconnect 4WD control unit connector. Turn ignition on and go to next step. 2. Check differential lock actuator circuit. Using ohmmeter, measure resistance between 4WD control unit wiring harness connector terminals No. 2 and 3. See Fig. 5 . Resistance should be less than 100 ohms. If resistance is as specified, go to next step. If resistance is not as specified, go to step 9 . 3. Check ground circuit. Check continuity between 4WD control unit wiring harness connector terminal No. 7 and ground. Continuity should exist. If continuity is as specified, go to next step. If continuity is not as specified, go to step 9 . 4. Check vehicle speed sensor circuit. Check continuity between 4WD control unit wiring harness connector terminal No. 10 and ground. Move vehicle slowly (at least 5 MPH). A pulse of continuity should exist for each 15.8" (401 mm) of movement. If continuity is as specified, go to next step. If continuity is not as specified, go to step 9 . 5. Check DIFF fuse circuit. Measure voltage between 4WD control unit wiring harness connector terminal No. 5 and ground. If battery voltage is not present, check and replace fuse as necessary. If fuse is okay, go to step 9 . If battery voltage is present, go to next step. 6. Check differential lock position switch circuit. Measure voltage between 4WD control unit wiring harness connector terminal No. 1 and ground. When differential lock indicator light is on, no voltage should be present. When differential lock indicator light is off, 10-14 volts should be present. If voltage is as specified, go to next step. If voltage is not as specified, go to step 9 . 7. Check 4WD position switch circuit. Measure voltage between 4WD control unit wiring harness connector terminal No. 8 and ground. With 4WD shift lever in "N" or "H" position, no voltage should be present. With shift lever in "L" position on Land Cruiser, "L4" on Tacoma, and 4WD on 4Runner, voltage should be 10-14 volts. If voltage is as specified, go to next step. If voltage is not as specified, go to step 9 . 8. Check differential lock control switch circuit. Measure voltage between 4WD control unit wiring harness connector terminal No. 4 and ground. With control switch off, no voltage should be present. With control switch on, 10-14 volts should be present. If voltage is as specified, go to step 10 . If voltage is not as specified, go to next step. 9. Check components and wiring harness. Check appropriate component (if necessary). See COMPONENT TESTS . Replace as necessary. If appropriate component is okay, check harness and connectors for terminal damage, corrosion or pins pushed out. Repair or replace as necessary and retest system. 10. Check circuit with control unit connected. Turn ignition off. Connect 4WD control unit connector. Turn ignition on. With differential control switch in specified positions, check voltage at 4WD control unit by backprobing connector. See Fig. 4 . See TESTING DIFFERENTIAL LOCK CONTROL OPERATION table. If voltage is not as specified, replace 4WD control unit. Fig. 5: Identifying 4WD Control Unit Connector Terminals Courtesy of TOYOTA MOTOR SALES, U.S.A., INC.http://www.2carpros.com/forum/automotive_pictures/62217_toy_1.jpg[/img]
Tacoma & 4Runner (2) 0.5 Or Less 1 & 7 On 0.5 Or Less 3 & 2 Off -On (3) 10-14 2 & 3 On-Off (3) 10-14 (1) Connect voltmeter positive lead to first terminal listed, and negative lead to second terminal. (2) With 4WD shift lever in "L"position on Land Cruiser, "L4" on Tacoma and 4WD on 4Runner. (3) Voltage is present for about one second then drops down to 0.5 volt or less.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
