2000 Saab 9-3 repair Question Won't Start Sometimes
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
2000 Saab 9-3 repair Question 4 cyl Front Wheel Drive Automatic 120000 miles
2000 9-3, 4cyl - periodically won't start out of the blue. Everything else works ie lights, radio, fans, but nothing going to the starter. After sitting for a while everything is back to normal and starts right up. My guess is a relay or something because the the alarm gets sensitive and sometimes the doors lock by themselves. Help?
hello certainly sounds to me like you have an immobiliser fault,could also be your key(linked to immobiliser system) have your key checked first or alternatively use a spare,failing key cheeck your ignition switch itself for faulty connections ,when the car fails to start is the immobiliser light flashing??if so then thats your problem in my opinion its unlikely to be a relay fault hope this helps regards irishmobilemechanic
did you ever get this figured out? If so, PLEASE TELL ME WHAT YOU DID! I've tried new fuel pump, relay, crank position sensor, ignition wires tightened, all keys, new batteries in key fobs. Nothing works. By the way, this only happens in the summer. I'm not kidding. It started last summer, but was fine in fall, winter and spring. Now summer is here again I've had it towed 3 different times. Argh.
It's probably the Neutral Safety Switch - seems to be a common problem and is happening to mine. Part is $300+ but you can bypass the switch...which is what I am hoping to do.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
