Car Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2000 Rover 25 Drove through water...
Posted at Mon Feb 08, 2010 11:33 am |
By
xmillyxxx,
Have Donated |
Give Feedback | Votes: 0 |
Engine Mechanical problem
2000 Rover 25 4 cyl Two Wheel Drive Manual 52,000 miles
I drove though around 3foot of water.. Car sat in it for about 2 hours before being recoverd. Have no water in oil or coming from pistons when cranked by hand.. However car will not start.. Just a single click. Will not jump/ bumpstart .. Any ideas!? |
Find a
car repair manual for your Rover 25 Repair Question.
Posted at Mon Feb 08, 2010 5:31 pm |
By
racefan966,
Certified 2CarPros Technician |
     (2963) Give Feedback | Votes: 44 |
Ok so have you tried to turn the engine over manually with the spark plugs out and in nuetral? |
Find a
Posted at Tue Feb 09, 2010 12:29 am |
By
xmillyxxx,
Have Donated |
Yes.. Still made the same single click! |
Find a
Posted at Tue Feb 09, 2010 6:50 am |
By
racefan966,
Ok so you can turn it over manually with a wrench? If so then pull the starter and take it to your local parts store and have them test it. |
Find a
Posted at Tue Feb 09, 2010 7:29 am |
By
xmillyxxx,
Have Donated |
You can only crank/turn it so far then it refuses to turn anymore.. the starter works fine as have removed it and tested it. Am thinking now that perhaps it is piston related?. |
Find a
Posted at Wed Feb 10, 2010 7:41 am |
By
racefan966,
So have you removed all the spark plugs and then tried to crank it over to see what it does? |
Find a
Posted at Wed Feb 10, 2010 8:51 am |
By
xmillyxxx,
Have Donated |
All spark plugs removed.. When you try to manually crank, will only crank quater.. Maybe halfway, then stops! Also, piston's are 3 up 1 down.. The manual states should be 2up 2 down.. Air filter was sodden so am guessing water has been taken into engine..
All electrics work fine as does starter motor/ battery/ fuel pump.. |
Find a
Posted at Thu Feb 11, 2010 6:44 am |
By
racefan966,
Ok so tell me how much oil is in it? When you went through the water did it die from takiing water into the engine? The two up and two down is at TDC on number 1 cyl. Also what RPM was it at when it died? |
Find a
Posted at Thu Feb 11, 2010 8:10 am |
By
xmillyxxx,
Have Donated |
It has plenty of oil in..almost full. I was going around 10/15 mph when I drove into the water.The car just stopped dead..So im guessing that when the exhaust got under the water..the engine took in water at that point killing the engine? |
Find a
Posted at Fri Feb 12, 2010 8:03 am |
By
racefan966,
No that wouldn't have killed it other wise I could have killed my truck everytime I dock my boat. It took water into the intake that is why the air filter was wet. How wet was the air filter? What I am thinking is the water got into the engine and hydro locked it and maybe bent a rod or something. So what you do now it bring the timing up to tdc and check the cams are they aligned (see pic) and check the pistons to make sure they are as they should be.
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
