Auto Repair Chat - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2000 Pontiac Grand Prix P0449
Posted at Fri Nov 06, 2009 4:41 pm |
By
Jhoium1,
Likes to hang around! |
Give Feedback | Votes: 0 |
Engine Mechanical problem
2000 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic 118000 miles
The car, after sitting for a few hours will start and idle for about ten minutes before it the rpms start going wild, it then drops to about 200 rpm and bucks in between 200 and 800 until the engine slowly stalls out. If i drive it it does the same thing if i step on the gas and try to get up and go. Its throwing out pcode P0449, which it has a new purge solenoid, new vent valve, new fuel pump and filter, and also has a new pcv valve.... Im at a loss on what could cause this. Any help would be great. Btw the car is aGTP so it is supercharged with the 3.8 V6 |
Find a
car repair manual for your Pontiac Grand Prix Repair Question.
Posted at Sat Nov 07, 2009 4:19 am |
By
mmprince4000,
Certified 2CarPros Technician |
                     (2159) Give Feedback | Votes: 35 |
If you are only getting the P0449 code, I would start by measuring fuel pressure with mechanical gauge.
Another possibility is a clogged CAT. If CAt is bolted on, remove bolts and inspect CAT, if you see any melted material, then CAT is bad. |
Find a
Posted at Sat Nov 07, 2009 8:21 pm |
By
Jhoium1,
Totally weird, i found a forum with the same car and problem and said it was a mass air flow sensor...so i tried it and it worked! The P0449 code no longer and the car seems to be running stronger then ever! |
Find a
Posted at Sun Nov 08, 2009 6:01 am |
By
mmprince4000,
One would think that if the MAF was bad it would set a MAF code? . |
Find a
Posted at Sun Nov 08, 2009 7:09 am |
By
Jhoium1,
Lol thats y i wasted 150.00 bucks trying diff parts of the fuel EVAP system! Wish it would have set a code for it. |
Find a
Posted at Mon Nov 09, 2009 6:14 am |
By
mmprince4000,
Glad it's running, thanks for using 2carpros. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
