Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Auto Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Car Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How to Use Test Equipment
Auto Repair Manual Car Maintenance Information
Vehicle Repair Service Engine Soon Light
Vehicle Repair Car Parts and Equipment Store
Vehicle Repair How Does it Work?
Vehicle Repair Safety Inspection
Auto Repair Manual Online Car Repair Manual
Vehicle Repair Smog Test Preparation
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2002 Volkswagen Golf Idle
Auto Repair1997 Pontiac Grand Am D...
Auto Repair1986 Ford Bronco Wont S...
Auto Repair1996 Dodge Caravan All ...
Auto Repair2004 Dodge Durango Wont...
Auto Repair1999 Other Mitsubishi Mo...
Auto Repair2005 Ford Explorer Whin...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2000 Pontiac Grand Am Steering Problem
Welcome to our question and answer forum where over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Goto page 1, 2  Next
Posted at Wed Aug 06, 2008 11:10 am
By Pirate!!, Likes cars!
Give Feedback | Votes: 0
Steering problem
2000 Pontiac Grand Am 4 cyl Two Wheel Drive Automatic 118000 miles
The steering wheel does not seem to return to center after I take a left hand turn. At that time, it also pulls very hard to the left. If I stop, turn the wheel all the way to the right and then back to center, it will not pull to the left until or unless I make another left hand turn. I have had four different people look at the front end. They said the ball joints, the struts, the tie rod ends are O.K.. Only one found that the left side of the stabilizer bar (where the link bolt goes thru it) is cracked.
Can a cracked stabilizer bar cause this type of problem or would it tend to be an indication of something else, such as, a problem with the rack & pinion?
Please help.
Find diagnostic tools, replacement parts or locate a car repair manual for your Pontiac Grand Am Repair Question.
By Advertisment,
Posted at Wed Aug 06, 2008 11:25 am
By merlin2021, Certified 2CarPros Master Technician
Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2Reputation: 593.2 (593) Give Feedback | Votes: 48
It's either the rack bearing preload adjustment, or the flexible coupling at the end of the steering column. POWER CENTER-LINKED RACK & PINION -2000 Pontiac Grand Am SE
Page 1 of 1
RACK BEARING PRELOAD
1.Raise and support front of vehicle. Center steering wheel. Loosen adjusting plug lock nut. Turn adjusting plug clockwise until it bottoms in housing. Back off adjusting plug 50-70 degrees. 2.While holding adjusting plug stationary, tighten lock nut to 50 ft. lbs. (68 N.m). Test drive vehicle, ensuring steering wheel returns to center after turning.
© 2007 Mitchell Repair Information Co., LLC.
http://www.ondemand5.com/mric/common/asp/printart.aspx
8/6/2008
Posted at Thu Aug 07, 2008 10:56 am
Thanks for the info regarding adjusting the rack bearing preload adjustment. What I am curious about is; the adjusting plug lock nut you are refering to is right on the outside of the adjusting plug in plain view when you look under the car, right? Or do you have to actually remove the the flexible coupling to get at the lock nut?
Also, if this adustment does not work, how do I install a new flexible coupling? Do you have instructions for that?
Please help.
Posted at Thu Aug 07, 2008 11:08 am
The plug is on the outside of the rack, You don't have to remove the coupling. That is for you to inspect for damage, if it's ok leave it alone...if it binds during turns and there is visible defects, replace it.
Posted at Thu Aug 07, 2008 11:15 am
Do you have a diagram that shows the location of the plug on the rack?
Posted at Thu Aug 07, 2008 11:35 am
Yes it's the verticle portion that connects to the column.
Posted at Thu Aug 07, 2008 12:20 pm
Is the adjuster plug in plain view when you get under the car or do you have to remove something to get at it?
Posted at Thu Aug 07, 2008 12:29 pm
No, you will see it...
Posted at Fri Aug 08, 2008 6:08 am
I have had a lot of people tell me that if the rack and pinion is having a problem it should be replaced because as it wears it puts metal flakes into the power steering fluid and the flakes ruin the power steeering pump. Is this true? If I adjust the rack bearing preload, and it solves the steering problem, will the rack put metal flakes into the power steering fluid that will destroy the power steering pump?
Posted at Fri Aug 08, 2008 12:16 pm
If you are worried about flakes, flush the system, disconnect the return line, have enough power steering fluid ready and a bucket to catch the flushed out fluid, start the car and add to the pump as the level goes down..a few quarts should do it. I have seen a few rack failures and havent seen the flake problem!
Goto page 1, 2  Next
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
