2000 Other Plymouth Models car over heats when the air condi
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
2000 Other Plymouth Models 4 cyl Two Wheel Drive Automatic 203334 miles
I need to find out why my car over heats when the air conditioner is used. I had a new thermostat installed about a week ago and the car still get hot. It even gets hot when the air conditioner is not used but it takes a while longer.
The AC will cause it to heat up faster because it requires more power from the engine. Have you had the radiator flushed? Also, make sure the radiator hoses, (upper and lower) are not collapsing from a vacuum.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
